Waxing will not solve the issue since waxes (true waxes at least) have no cleaners (whether chemical (solvents) - or mechanical (abrasives). Wax is just used to add a layer of protection.
Also, claying will not do anything because it's meant to remove paint overspray and other particulates that can't be rectified by polishes.
You will need a general purpose polish like our
einszett Paint Polish . It will clean the paint chemically and remove oxidized and damaged paint revealing the undamaged paint and therefore restoring gloss.
You'll want to apply it with a plush cotton towel (not those bulk bag of rags that scratch paint) and wipe off with a microfiber towel.
After application, apply a coat of wax over the polished surface to protect it. At this point, I suggest you do your entire car if you've never polished it before. It will make it look like new again. Polishing is responsible for about 95% of the gloss and depth factor you see on well maintained cars.
If Paint Polish is not enough to fix the area, you may have to treat that particular area with our
einszett Extra polish . I would apply it with a foam applicator pad (you can pick up at any auto parts store). After applying Extra, polish the same area with Paint Polish and then follow up with a coat of wax.
If you would like 1/2 oz samples of these polishes, let me know by emailing me at
[email protected] and I'll have some sent to you to try.
And if you have any questions, need more help, feel free to ask.
Hope this helps!
