View Poll Results: APR 1+ w/supporting mods, which spark plugs??
Voters
18. You may not vote on this poll
  • NGK BKR6E, 0.028" gap
    2 11.11%
  • NGK BKR6E, 0.030" gap
    0 0%
  • NGK BKR6E, 0.032" gap
    2 11.11%
  • NGK BKR7E, 0.028" gap
    5 27.78%
  • NGK BKR7E, 0.030" gap
    5 27.78%
  • NGK BKR7E, 0.032" gap
    2 11.11%
  • Bosch FR5DTC, 0.028" gap
    2 11.11%
  • Bosch FR5DTC, 0.030" gap
    0 0%
  • Bosch FR5DTC, 0.032" gap
    0 0%
  • Other, please specify in a post
    0 0%
Results 1 to 17 of 17
    Senior Member Three Rings Kengineer021.8's Avatar
    Sep 26 2006
    Whittier, CA
    APR 1+ Spark Plug Question
    I have been searching for about an hour, but it's hard to come up with one answer regarding spark plugs.
    I live in Redding, CA and in the summers we can see temps well above of 110 F, RaceTec FMIC will be coming soon, and I wanted to change my spark plugs.
    I'm leaning towards NGK BKR6E's, or should I be leaning towards the 7E's?
    Also what is everybody's recommended gap? I'm thinking 0.030", but others have said 0.028", 0.030", or 0.032".
    TIA
    Last edited by Kengineer021.8; 04-30-2008 at 02:43 PM. Reason: hotter than h3ll....
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    Re: APR 1+ Spark Plug Question
    you got to be joking right??? its 110 in the shade!!! J/k!!!
    I would say its actually a bit higher. I would say we can see asphalt parking lot temperatures @ about 130. Back yard air temp is around 115-120.
    This is a good question, I want to know when I install my 1+ revo (need intercooler and clutch first......)
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Sep 26 2006
    Whittier, CA
    Parking lot temps of 130 for sure. The heat up here is no joke, that's why I need that FMIC to get here!!!
    Go: APR Stage 2, TT 225's, Forge 007 DV, STaSIS SS, RS4 Rear Sway, RaceTec FMIC, Forge TIP
    Show: 19" GM VMR 708's, Delsa S4 Spoiler, Blacked Out Grilles, Tint, Smoked Side Markers, De-Badged, RS4 Engine Cover, Aero Wipers, RNS-E, CC, Tinted Tails
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Go 7's gapped to 0.28
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Bosch FR5DTC's. I had an issue with the spark blowing out on my car with BKR's and these fixed it!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 28 2008
    San Diego
    please clerify:
    spark blowing out?
    Mar 21 2006
    Lakeland, FL.
    The plugs were not able to keep the spark under boost.
    I'm back bitches!
    Buncha motorcycles
    Memphis, TN
    oem work fine for me
    you will be amazed how much harder your car pulls with the racetec!
    APR Stage 2/AWE Intake
    Sep 26 2006
    Whittier, CA
    bump for poll
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Quote Originally Posted by dirtybrd View Post
    I may have to try these because I think this is happening to me. Feels like its hesitating under load.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    NGK BKR6EIX, if too hot, then BKR7EIX. All gapped at .028
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Jun 30 2007
    Raleigh, NC
    im gonna be running the bosch fr5dtc's -- you might have trouble finding them, but any shop that works on porsches will have plenty of them in stock. i found them for 3 bucks each at a local shop.
    chris -- what gap are you running on yours? i was gonna gap to .03
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Sep 26 2006
    Whittier, CA
    I need more votes!!!! I too am feeling like I'm losing my spark under load so I'm leaning towards the Bosch FR5DTC's or NGK BKR7E's.
    Sep 26 2006
    Whittier, CA
    ttt
    Sep 26 2006
    Whittier, CA
    Any more votes??
    Only 9 opinions... I don't believe that for a second!!!
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Registered Member Two Rings roostboost's Avatar
    Apr 21 2008
    long island
    general rule of thumb is that for every 100hp increase over stock you go one step COLDER on the spark plug....the gap should be as big as you can go w/out "spark blow-out" etc...I'm about to run NGK plugs BKR7EIX w/a .028" gap and see how she drives.
    08 A4 2.0T TIP Ocean Blue Pearl/Milltek cat-back/Eurocode Testpipe/KW V1 CO's/5000k HID's/ECS Front Plate delete/Clear sidemarkers/ITG air filter/20% Tint/
    2005 EVO 8..ETS HTA35r turbo setup w/all the bells and whistles runnin' on E85...550whp+ on "conservative" tune
