Results 1 to 9 of 9
Thread: timing belt
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    timing belt
    Ok Hi to all. Did someone know where a can get the tools needed for cams and crank. I don't want to pay too mutch for it b/c i might use it only once.
    Unless there's somebody close want's to lend me one, like guruman? Because i think the dealer is too expensive for a tool that i may only need once. Or do you know a beter place to go?
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    Re: timing belt
    www.ecstuning.com has the cam locking tool. Not sure what you were looking to spend.
    Dec 06 2007
    Calgary, AB, Canada
    Re: timing belt
    You can expect to spend ~$100 on the tool if you buy it new from a tuner.
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: timing belt
    youre saving enough money doing it yourself to buy the ECS one, or shell out more money and have someone else do it.
    Jan 12 2008
    WV
    Re: timing belt
    you don't need the tools if you mark the gears and belt good enough. Take your time before you remove the belt because you can't go back. I marked a single tooth from each cam on the belt and 2 teeth on the crank (used a paint pen and was sure to get plenty on both gear and belt). Then I transfered the marks from the old belt to the new belt (they should have the same number of teeth). Then the only way to screw up is to be off an entire revolution on any of the three gears which should never happen. If you decide to move either of the cam gears be sure to use a breaker bar or wrench and not a ratchet. If you are in the proper position the cam will be pressing one of the valves open so moving the gear in either direction will allow the valve spring to slam the valve shut moving the cam gear with it. The ratchet will let the gear spin free in one direction where the breaker bar or wrench will allow you to stop it. Good luck.
    Oct 14 2007
    Val-Belair
    Re: timing belt
    Quote Originally Posted by syxxty View Post
    Ok thank's a lot. I've already done timing belts on 4cyls engines but never on a v6. Your right. I'll take a good look and make marks and should be easy.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: timing belt
    i agree but it does help...
    definitely mark the gears anyways. 1 tooth and your gonna bend a valve
    Registered Member Three Rings Charlie's Avatar
    Sep 16 2006
    West Haven CT
    Re: timing belt
    I have the tool, 100 shipped its yours.
    |Stage 2+ B5 S4|
    FOR SALE
    Feb 17 2004
    Sterling, VA
    Re: timing belt
    Quote Originally Posted by Reich View Post
    I bought this set: http://www.zdmak.com/wbstore/main.as...91X3242&CTMP=1
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
