Results 1 to 9 of 9
Thread: Armrest rattle!
    Registered Member Two Rings
    Jul 29 2005
    Quebec
    Armrest rattle!
    Hi all!
    Am I the only one to have my armrest rattle?
    Anybody found a fix for this? I did search but found nothig.
    thank you
    Dec 19 2007
    York, PA
    Re: Armrest rattle!
    theres a series of bolts under the console that you probably need to tighten. I would suggest using threadlock so they dont come loose again.
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    Re: Armrest rattle!
    there is actually only one bolt that hold the armrest in. If this bolt is loose, you will no doubt need to take the rear ashtray and maybe the central lock button out to tighten it. I would check the cup holders on the inside though to make sure those arent rattling as that would be an easier fix.
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    Jul 29 2005
    Quebec
    Re: Armrest rattle!
    Speaking about Central Lock - where the heck is it? I dont have it on my car. it's 2003 1.8T
    thanks
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Re: Armrest rattle!
    any diy's? mine rattles like a mmmmotherf...!
    and my shifter too! i have to press down on the shifter a little for it not to make noise when going 3-5k accelerating.. anybody else has/had that?
    Feb 17 2005
    Sarasota, FL
    Re: Armrest rattle!
    My armrest rattles when its all the way up, usually just pull it forward a tad and the rattle goes away!
    Dec 19 2007
    York, PA
    Re: Armrest rattle!
    you have to take out the rear ashtray and the rear lock button....and it is just 1 bolt
    Senior Member Three Rings edge19lw's Avatar
    Mar 24 2007
    03' a4 3.0
    Queens, NYC
    Re: Armrest rattle!
    jesus, mine does this too its sooo f***** annoying , especially when your on the highway on a long trip and cant stop to fix it
    2003 A4 3.0 | Trunk Lip Spoiler | CC mod | Bilstein/H&R | RS4 Rear Sway Bar | K&N drop in filter | 23% Tint | Magnaflow 14851's & Magnaflow 10415's
    -Thomas
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Re: Armrest rattle!
    I was working in that area recently and had the armrest out. I also took some pictures that show the brackets for the armrest if you're interested. Armrest brackets at bottom of post.
    http://www.audizine.com/forum/showthread.php?t=206928
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
