Results 1 to 4 of 4
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Running e85 with revo
    Is anyone in Colorado Springs or Denver running E85 with Revo select plus ?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Running e85 with revo
    No, but I will most likely be making the switch over once I recoup some $$$ from my last engine build. You need to PM Denvernoob on this subject. He will tell you everything you need to know and then some. He was running straight E85 on his K04 and Giac programming. Now he has something ever better up his sleeves
    Nov 06 2007
    B5 S4
    Houston
    i may need to ask him about it ..I met somebody who was running an e85 program about two months ago ..I was told it would run like shit unless you got your fuel tables right so i have been pretty apprehensive on toying with it just yet
    Feb 12 2004
    Everywhere
    Denvernoob (Ted) is the only member in a B6 running E85 correctly
