    Jul 08 2007
    2007 2dr 6spd gti
    Hillsborough
    treadwear question
    i have falken 615 rts, i know they are not gonna last long but i need to know what tire pressure i should set them at to get the optimum mileage and treadlife, 225/40 r18 on a mkv gti
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: treadwear question
    If you want even wear for the entire treadface, the VW recommended PSI should be best. we don't carry Falken, so don't know if your tire has any "special needs" that would require a different number
    Jun 14 2005
    Anaheim, CA
    Falken Azenis RT615's have pretty low tread wear ratings. I would go by what the vehicle recommends for the load. Make sure not to under inflate or over inflate which can result in uneven tread wear especially noticeable on those tires.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Jul 08 2007
    2007 2dr 6spd gti
    Hillsborough
    yea i was asking because i heard from someone to put it at 90% of the maximum psi and i thought that was rather high
    Dec 01 2007
    Markham, Ontario
    while we are on this thread, what are the recommendations for 235/35/19 - proxies 4 ? for a b7 a4
