Results 1 to 9 of 9
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    OEM door speakers dead!
    my passenger side main door speaker is so blown im ready to drive my car off a cliff when i listen to music.. where can i get a replacement of either OEM, or aftermarket that will still work with the oem amps.
    does anyone know the specs on the stock lower door speaker? size, wattage, ohms?
    ThorTechnik.com
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Re: OEM door speakers dead!
    I second that.
    Where can you those speakers???
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    4" and 2ohm. Honestly if you happy with the way the systems sounds i would check the classifieds and look for someone selling their speakers OR put up a WTB post. Youll find someone within a few days guaranteed!!
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Quote Originally Posted by ny02s4 View Post
    Aftermarket speakers? I've heard going aftermarket can make it sound like shit if you're combining different brands or something...I would stay on the same side and look for a complete part out and grab the OEMs.
    Apr 01 2008
    Massachusetts
    I found this guy selling on ebay USED speakers Each for $97 shipped.
    Isn't that too much for used speakers?
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    you would be better off just replacing all your speakers than buying used due the fact they will probably take a shit in the next month and you wont have any warranty.
    with most aftermarket speakers you'll have to make a custom bracket to mount them, but its not that bad.
    B5 S4 AWE Stage 3 - sold
    Mar 07 2007
    Belmont, MA
    if i were to go aftermarket, i would replace both front door speakers in order to maintain a more even sound. so the lower door speakers are 4"@2 ohm? what kind of power should i be looking at?
    ThorTechnik.com
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Shokan will have the used parts you are looking for. The OEM speakers are a unique design. they are very low impedence. If you replace them with an aftermarket selection, you will likely end up with a 4ohm speeaker, which will reduce the output of the factory amp to those speakers. by up to half! Though there may be some 2ohm 4" speakers out there, OEM is best unless you are replacing the amp also and doing a higher end system.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Registered Member Two Rings
    Mar 21 2008
    va
    Easy, go to parts express and pick out a 4" 2 ohm driver. Or add resistors like you have to do to the ford systems.
