Results 1 to 15 of 15
    Senior Member Two Rings Johns_Orange_b5's Avatar
    Dec 20 2006
    millbrae
    Ok guys really need help this time
    Alright guys, this time I'm pretty lost as to whats going on. Did a hard 1st gear pull and switched hard, got to the light and the car started sounding like a wrx. Got the car towed home, vag'd it and got
    16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    P0012 - 35-00 - -
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16687 - Cylinder 3 Misfire Detected
    P0303 - 35-00 - -
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-00 - -
    16686 - Cylinder 2 Misfire Detected
    P0302 - 35-00 - -
    16685 - Cylinder 1 Misfire Detected
    P0301 - 35-00 - -
    for about a month now, the car would misfire at idle and just go away within seconds, I just kept assuming it was a bad coilpack since this is like my 3rd set already. But after pulling the codes it doesn't look like it. at first I thought it was the cam tensioner but I can't tell since theres no ticking this time and the guides aren't broken. Checked for vacume leaks and I don't see any major ones, whats weird is that I sometimes hear like a rattling metal sound sporatically just for a second and it goes away. I really need help guys I'm really lost this time.
    Apr 25 2007
    millersville, maryland
    Re: Ok guys really need help this time
    Dec 20 2006
    millbrae
    2001 audi a4 1.8tqm
    28rs elim
    550 rc injectors
    installed about 15-20k miles now
    Dec 20 2006
    millbrae
    hrmmm...idunno if its a coincidence, but when I pulled the valve cover off and tried to compress the tensioner, it was tight and had almost no play, which matches exactly what that link says, but when I called VWspecialties which is suppose to be one of the best in the area, I told the guy their Don i think his name, that it was tight and he said it should be, he also said it wouldn't cause misfires in all cylinders.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Johns_Orange_b5 View Post
    P0012 - 35-00 - -
    P1136 - 35-00 - -
    P0300 - 35-00 - -
    P0303 - 35-00 - -
    P0304 - 35-00 - -
    P0302 - 35-00 - -
    P0301 - 35-00 - -
    Obviously all your P030x codes are for misfires, I know you said you replaced the coils, have you checked and regapped your plugs?
    As far as the Camshaft position code, I don't know what to tell you. Unless for some reason your intake cam jumped a tooth, but that shouldn't be able to happen if your tensioner is still in good condition. AFAIK there's supposed to be 16 links between the two cam timing marks, might be a good idea to check that. I've seen guys get a tooth off on a timing belt and not notice it while driving, it'll come back in a day or two w/ codes for misfires on that bank.
    The misfire at idle may be a timing issue as well. The ECU can compensate by retarding timing in some cases to cancel the misfire.
    Is it misfiring at higher RPM's or just at idle? Boost sensitive, anything else more specific.
    You're running the correct fuel right? No offense, but I've seen it happen.
    Good luck
    Dec 20 2006
    millbrae
    the chain timing is on spot, the timing belt I havent checked yet, I don't think it could be off since its been good for 45k miles. I havent checked gaps yet I'll check it tomorrow as well as the cam position sensor. Of course I only use 91 mobile 1
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    You've got a 91 oct file on a GTRS?
    I thought it would've been a 93 oct file.
    As far as checking the cam pos sensor, it should be a hall effect like mine, it's not real easy to diag w/ a logic probe or a Digital Multimeter. Make sure you don't start probing wires with an analog meter. Your ECU will never forgive you, just an FYI, if you didn't already know.
    I think I still have the wiring diagram around for the cam pos sensor if you need it. There should be three wires, 5V ref, ECU feed, and Ground. IIRC the ECU feed/sense wire is the middle wire, but don't quote me on that.
    Feb 27 2005
    North Wales, PA
    check your timing belt. set the rotating assembly to tdc and see where your cam sprocket is. the grooves should match.
    Senior Member Three Rings sbghms's Avatar
    Jan 02 2008
    2001 Audi A4 1.8TQSM
    WA
    Is that a bad thing. Jk i love WRX's.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I would get that bitch at TDC like poopie said. I have seen the teeth jump before on my friends 1.8t. Verify that, then start messing with the plugs and such.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Established Member Two Rings 1hotA4's Avatar
    Apr 25 2008
    My little 2001 A4 2.0T
    Atlanta, Ga
    Your misfires are probably from bad plugs. I just changed mine out b/c i was having misfire problems as well. Also the MAF sensor went out in my car. (Like they always do!) FREAKIN GT28RS
    BetaAlphaTau Member #37
    "Opinions are like Assholes, everyone has one!"
    Dec 20 2006
    millbrae
    I fuel with the highest fuel grade available in the area, 1hota4 but the cars running real real bad, not just random misfires, its misfiring consistantly, i'll check the timing tomorrow as well as the plugs
    Apr 25 2008
    Atlanta, Ga
    Mine is at the shop right now b/c i blew a MAF sensor and come to find out my car was misfiring like hell. He ran the car on his computer. So he pulled my plugs and replaced them with new ones and bam! No more missfires...
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Quote Originally Posted by 1hotA4 View Post
    how do you run a car on a computer? wouldnt that break the computer?
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Quote Originally Posted by maxspeed View Post
    He probably means VAG-COM'd and got misfire codes/counts.
