Results 1 to 33 of 33
Thread: crankshaft
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Question crankshaft
    What purpose does the large "gear looking" thing at the back of the crankshaft serve? The part I speak of is inside the block between the 4th cylinder and the back of the block. Any one know?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: crankshaft
    Are you talking about the crank trigger wheel?
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    Re: crankshaft
    sounds like it
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: crankshaft
    please tell me you didnt bend it Jon...
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    Re: crankshaft
    for the engine speed sensor
    Genesis Autosport
    Evolution Racewerks
    97 A4 2.0TQM
    Rochester, NY
    Re: crankshaft
    Yep it's the 60-2 wheel for the VR sensor (engine speed sensor/crankshaft position sensor, etc)
    Car won't run if it's fucked up.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Re: crankshaft
    Thats the bit left on the floor once the engine is assembled and in,lol
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Jan 06 2007
    NH
    Re: crankshaft
    no I didnt fuck it up, but the company who did my bore and stroker clearance left the ABA one on and didnt put my ATW one on as I asked them to, so Im assuming Im gonna need them to go ahead and switch that out huh? God damn it...
    Oct 27 2007
    In the lab
    Re: crankshaft
    058 1.8t's use the same trigger wheel as on the ABA's... my 2.0 runs just fine with a ABA crank and trigger wheel
    no worries!
    Jan 06 2007
    NH
    Re: crankshaft
    ...wait should I swap it out or will that give me ignition problems? with a different cranks and different stroke should I keep the ABA trigger wheel on it?
    Jan 06 2007
    NH
    Re: crankshaft
    Quote Originally Posted by 317ssayzarc View Post
    no worries!
    I'll try it, but when I visually inspected them there was a noticable difference between the two. Im just not sure if I want the stock wheel or the correct wheel for the crank that in there right now
    Oct 27 2007
    In the lab
    Re: crankshaft
    Quote Originally Posted by Euro-Tuner View Post
    all the trigger wheel does is provides a means for the crank sensor to get signal... the rings are the same on both your stock and the aba crank, same size, shape, and same number of holes
    Jan 06 2007
    NH
    Re: crankshaft
    I'll take your word on it, but I did see a difference as far as the teeth on the wheel. I guess if worst comes to worst down the road I drop my subframe, pull off my oil pan and pop out my crank...hopefully it doesnt come to that
    Oct 27 2007
    In the lab
    Re: crankshaft
    mine runs awesome with the ABA crank/trigger wheel, have no fear
    Jan 06 2007
    NH
    Re: crankshaft
    ok thanks. Mike, you using the ABA crank correct? did you leave the trigger wheel on the ABA crank?
    Jul 07 2004
    socal
    Re: crankshaft
    Yes I am on my 2nd ABA crank. Not sure which trigger wheel I have on the car, but I could always ask 034.
    Jan 06 2007
    NH
    Re: crankshaft
    would you please?
    Oct 27 2007
    In the lab
    Re: crankshaft
    im not good enough?
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: crankshaft
    I switched mine back, they were noticeably different between the AEG and AMB motors, Keep in mind you do need new screws they are stretch ones so the old ones will not work
    - Clint
    Oct 27 2007
    In the lab
    Re: crankshaft
    you are 06A block homeslice
    very true, its a must!
    Jan 06 2007
    NH
    Re: crankshaft
    im not good enough?
    you numero uno in my book, I just value multiple opinions and applications
    Oct 27 2007
    In the lab
    Re: crankshaft
    absolutely, i was just poking fun i asked several people i trusted the same questions before i did a few things on my build, after they all said the same thing i had no doubt i was doing the right thing... theres some threads on vortex with this info that i remember reading, may want to do a search over there
    Jan 06 2007
    NH
    Re: crankshaft
    bump for Mike's info from 034
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: crankshaft
    No?
    Leave it...its fine.
    Jan 20 2005
    99 AJL TQS
    UK
    Re: crankshaft
    The master has spoken, good news for the OP
    -Mark -
    Oct 27 2007
    In the lab
    Re: crankshaft
    plus Bob Q said the same thing in his thread he made over on the 'tex
    Jan 06 2007
    NH
    Re: crankshaft
    that makes me happy
    Jul 07 2004
    socal
    Re: crankshaft
    I talked to Javad and he said I am running the ABA wheel on the ABA crank.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Re: crankshaft
    Do you guys recommend getting a used crankshaft machined?
    97 A4 2.0TQM
    Rochester, NY
    Re: crankshaft
    er, what do you mean by that?
    you'll want to get it checked and checked for straightness and polished (maybe magnafluxed too?) but that's all you need to do...
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: crankshaft
    machining as in knife-edged counterweights?
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Re: crankshaft
    Quote Originally Posted by pac1085 View Post
    Yea thats what I meant. My machinist, recommended that I have the journals "turned" so the bearing surfaces are clean and the right size for the bearings. I never heard anyone meantion it thats why i asked.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: crankshaft
    Quote Originally Posted by turbo944s2 View Post
    The only reason you should ever need the journals turned or machined is if there's a taper or out of round journal.
    The other possibility is that a journal may be worn, or had a spun bearing previously. If it's salvageable, you can turn the journal down and use an "OS"(oversized) bearing. Bearings made for a non-OEM spec bore/diameter are labeled as "OS0.005", "US0.005", or similar. The number is how many thousandths the bearing is larger or smaller than OEM spec.
    This can be beneficial in the racing world, but I'm not sure where you would find bearings like that for a VW/Audi.
