Results 1 to 17 of 17
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Suspension ?: do the 2001 Sport Package and S4 "share" technical points-
    Spring rate, ride height, rebound and compression settings, yadayada.
    TIA!
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Registered Member Two Rings
    Apr 13 2008
    Westlake, OH
    Re: Suspension ?: do the 2001 Sport Package and S4 "share" technical points-
    TIA = This Is Africa?
    Feb 27 2005
    North Wales, PA
    No, much different. They are physically the same as far as mounting goes, but struts and spring rates are different.
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by FACT View Post
    Thanks in advance.
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    LOL!!
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Anyone want some B5 S4 springs and shocks? 60k miles. Perfect working order when removed for Coilovers. $100.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Quote Originally Posted by Poopie View Post
    SO, if I COULD acquire a set of S4 B5 hardware, a swap would be a good thing?
    Forum Moderator Four Rings docurley's Avatar
    UK London
    No as the springs would jack the car up although the shock could be used as a cheap upgrade.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The shocks are pretty much the same. Some say the damping is different but I've run two sets of 1.8t sport struts with a set of S4 struts between and didn't notice any difference. If there is a difference it is a very small one. I ran them with 1.8t sport springs and it was fine.
    The springs are not the same. They would raise the front of the car even higher than the S4 which is already noticeably higher than a stock sport 1.8t A4.
    Jim
    I Do Werk.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Danke, alles.
    I thought the rate would leave the nose 'up' a bit. Will check out the strutz/shox differences.
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    How about this.......
    Who gives a shit?
    Get Some quality coilovers for your A4 and forget the S4's setup.
    And yes, ECS/Bilstein combo is a cheap kickass combo!
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Most of the reason the S4 stuff isn't compatible is because the weight the S4 has, necessitates need for different spring rate.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Quote Originally Posted by Rosati View Post
    Who gives a shit?
    Enjoy your genteel life in NJ do you?
    FWIW, I track my TT already, and don't need C/O to pass man-test. Since I use the Avant for ACNA and Audi Motorsports events as an organizer, I'd rather not get C/O.
    Stop tryin to impose your world-view on the rest of us. We grew up already.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Quote Originally Posted by Nor_Cal_Driver View Post
    Thanks. I appreciate confirming the sense I got. Probably get FSD/Eibach and let 'er rip as a grocery getter and event truck!
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    not 100% sure but the 2.8 sport shocks should be the same (or closer to) the S4's than the 1.8 sport shocks.
    i'd still possibly be interested trading my Bilstein pss9's on my 2.8 for some S4 sports. so far i've never had a serious offer. that, or one guy needed them in a week and wasnt' very flexible. oh well. no hurry, i still love them.
    Mar 09 2004
    nw michigan.
    Koni FSD are not available for our cars. If they were I'd be running them. Even more so if they were available as coilovers.
    The S4 and 1.8 struts felt the same to me. Looked the same, smelled the same, etc..
    If you are going with a softer street setup then the H-Sport bars are even more important. I've run with and without them and the difference they make with stock sport is unreal. I've run them on the track this way too. The brake dive is exaggerated but the steady state and dynamic cornering are excellent and way beyond what I expected.
    The brake dive. 235/45-17 Pilot sports, Carbotech Bobcat pads, A8 kit.
    These are more telling than they may first appear. I'm carrying 600 pounds more weight through the corners than the GTi and am still reeling him in. I was nowhere close to the apex and still had to back off. With proper lines I could have slid past but passing was only allowed on the straights in this run group. He was quicker than me on the straights and had to coast as I struggled to pass. Through the curvy parts I put some serious distance on him, the other GTis, and an R32 that sounded beautiful. At max cornering load the outside wheel gap closes by about an inch which is crazy considering how soft the stock sport springs are. You can see the inside gap opening up about an inch over how the car sits when still.
    Jim
    I Do Werk.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Excellent insights and pics. Since I have an Avant, your thread (1more) really shows the outcome well.
    Lou, we may have an extra set of B5 S4 gear runnig around in a box.
    Thanks all.
