View Poll Results: Which Turbo Upgrade for the Tip?
Voters
35. You may not vote on this poll
  • K04
    3 8.57%
  • GT2X
    2 5.71%
  • GTRS Eliminator
    23 65.71%
  • Stage I+
    7 20.00%
  • Leave it at Stage I
    0 0%
Results 1 to 26 of 26
    Jan 10 2008
    Midwest
    Turbo Upgrade for Tiptronic (POLL) - Need Advice =)
    Hey guys i would like to upgrade the turbo on my car this summer and was looking for advice as to what would be best. I'll be doing the install myself with some of my buddies so labor cost doesnt worry me at all.
    Right now i have GIAC Stage I, i liked it for the first few weeks and now want more . I was looking at a few options out there
    1. K04 , alot of people have this. Some say they like it others say they wish they stayed with K03. Power is ~250HP?
    2. GT2X Kit. Haven't heard much about this kit, it looks like its right inbetween the k04 and the elim so it might be an option. ~300HP?
    3. GTRS Eliminator Kit. I saw another person had this but im not 100% sure wether or not the elim will work with a tip tranny and what would be required to run it safely. ~350HP?
    4. Or just go Stage I+/II
    Comment/Suggestions Welcome ... Just dont tell me to get a manual tranny lol i wana make the best out of what i got
    -Ado
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Turbo Upgrade for Tiptronic (POLL) - Need Advice =)
    I'm curious... is the k04 250whp or crank hp? Because what's the point of going k04 when an APR 1+ chip gets you 245 crank hp?
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    get the large injector file from Giac and some 386cc injectors and try that first. It will liven up your car quite a bit.
    WTB K04 turbo ASAP
    http://etektuning.com
    Veteran Member Four Rings Dylan's Avatar
    Mar 28 2008
    i'm also wondering about this...
    i read somewhere that BMW, on the 335i, went the route of 2 smaller turbos instead of a big one to reduce lag - has anyone TT'd their 1.8, and if so, what kind of power are they pushing as a result?
    sorry for the hijack - FWIW, i'm voting stg I+
    BRING BACK GCC REP!!
    jason1st: If you just want a good job and to be able to take care of your family with a lot of security etc. Canada is a great place for that.
    If you want to crush your enemies, see them driven before you, and hear the lamentations of their women, then the United States is where you should be.
    (_|_) 4
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Go with the GTRS.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    GTRS; it has the most linear torque band, whereas, the k03 & k04 all have characteristic boost spikes that probably aren't too good for an automatic
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    Well for one, stage 1+ and stage II are two completely different things.
    Like evola said, get the injectors and the large injector file first. With that comes an upgrade in the DV. That will put you to stage 1+.
    If you go stage II, you'll bolt on a K04. If you do that, you'll want to replace not just the DV, but the TIP and add on a FMIC or SMIC.
    I voted for the elim kit. Go big or go home.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Why not a 71R Eliminator??
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Jan 10 2008
    Midwest
    Quote Originally Posted by RLB6 View Post
    Heheh well my concern is with the tip tranny. I don't wana go BT and then have the tranny go out on me . Is your TIP stock or did you have to upgrade anything on it to achieve those #s and run the elim kit?
    Jan 10 2008
    Midwest
    Is Stage 1+ really worth it over Stage 1? I mean is the hp/tq diff noticeable?
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by -=Ad0=- View Post
    yes, it is just as big of a difference from Stage 1 to Stage 1+ as it is from stock to Stage 1
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Dec 06 2007
    ^^agreed, but only go GIAC with ur 1+!!!!!!!!!!!! APR's tranny programming sucks and u'll get very aggravated from the drive! i drive 70 miles a day and it gets so annoying!!! it's never in the right gear!
    -Kirk
    BetaAlphaTau Member #58
    Jan 10 2008
    Midwest
    Quote Originally Posted by AudiA4Turbo22 View Post
    If i did Stage 1+ id go with GIAC since we have a local tuner up here
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    GIAC is not great either. The worst is when in D and under light / medium acceleration. boost is up and down like crazy.
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Apr 16 2008
    Utah
    I hope you enjoy pinging.
    GIAC 1+ is too aggressive for TIP cars.
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    That’s why you should just stick with a KO4 with "all the trimmings" as mentioned on here; i.e. Exhaust, Injectors, maybe some heat shielding on the intake side to compliment an upgraded SMIC or do the DSMIC. Or if you don't mind the FMIC look...
    Previous
    USP B6 A4
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Add a EBC to the Elim setup, run it at lower boost levels and bump it a little at a time or after having the kit on the car for some time.
    Tq is what is going to kill the trans not the amount of hp your making, the K04 has a much quicker tq band which means it would put the most stress on your transmission vs a setup like the BT's which have a smoother tq band.
    Veteran Member Four Rings redline_redline's Avatar
    Dec 18 2006
    Vienna, VA
    Quote Originally Posted by rccks96 View Post
    It's not too bad if you learn how to control it. The worst part is when you're on the highway in 5th (tiptronic) and accelerate past 4k rpms, itll automatically kick into 4th, and back into 5th, and back into 4th. So you have to understand it and know how to drive it well. But overall I love it and it was 100% worth it. I just wish it was the first thing i did to my car.
    2012 Phantom Black S4 ~ RS4 Grille ~ 19x9.5 ET45 Gunmetal V710s w/ MPSS 255/35/19 ~ Magma Red Silk Nappa ~ Carbon Atlas Trim ~ Alu Optics
    Gone: 2002 Denim Pearl Blue A4 ~ GIAC FX-K03 Stage 1+ ~ Genesis 380cc ~ Retrofitted USP front with custom mesh grills ~ S4 Rear ~ ACE 18" Hyperblack RS4s ~ Custom Magnaflow w/14851s ~ Hyperboost Compact ~ BoostedTech ~ RS4 Rear Sway ~ FK Housings ~ LED tails ~ M3 Lip Spoiler ~ SPP Yellow Fogs ~ 20% Tint
    Sep 20 2006
    MD
    My tranny is stock, along with my TQ. Both are stock. I've had my BT kit for over a year now with no problems! And yes, I do drive the piss out of it!
    Aug 26 2005
    Quote Originally Posted by redline_redline View Post
    You can recode the TCU to stop the tip mode auto gear shifts. Disabling DSP may help the shift point errors with APR's tuning.
    Try "0001102" to hold selected gear in tip mode, and "0001112" to also disable DSP.
    Registered Member Two Rings roostboost's Avatar
    Apr 21 2008
    long island
    I talked to my local audi tuner/specialist and he said the TIP tranny in my B7 is good for about 300whp/300lb. ft. of torque. I'm not sure about the other model yr. trannies.
    08 A4 2.0T TIP Ocean Blue Pearl/Milltek cat-back/Eurocode Testpipe/KW V1 CO's/5000k HID's/ECS Front Plate delete/Clear sidemarkers/ITG air filter/20% Tint/
    2005 EVO 8..ETS HTA35r turbo setup w/all the bells and whistles runnin' on E85...550whp+ on "conservative" tune
    Jan 10 2008
    Midwest
    Quote Originally Posted by roostboost View Post
    Could you ask your dealer what the Tip tranny in an '02 B6 is good for?
    Jan 10 2008
    Midwest
    What kinda mileage do you have on your Tranny bro?
    Sep 20 2006
    MD
    I have about 91K on the odometer.
    Apr 21 2008
    long island
    Sure, I should be talking to him in the next few days and i'll post up or pm you what he says about the b6
    Jun 30 2007
    Raleigh, NC
    GTRS ftw.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
