Results 1 to 15 of 15
    Established Member Two Rings kobefans's Avatar
    Nov 19 2006
    Vancouver
    Ok, Wtf happened to my audio?
    long story short... my car got impounded for 2 month and the battery died couple times, today i got the car, re-charged the battery. when i tried to turn on my radio.. it doesnt work anymore... all the display had nothing on. but all my other electric works including ac..
    any idea what should i do here?
    97 QMT
    Bilstein sports + H&R race || Ebay Short Shifter || ASA 18 black mesh wheels || DEPO 2-piece Headlight || 6000k HID || Smoked Taillights || Carbon Fiber Hood || chipped APR 91 Program
    exhaust to be done !
    Deactivated Four Rings
    Nov 19 2006
    MMM
    Re: Ok, Wtf happened to my audio?
    Quote Originally Posted by kobefans View Post
    Fuse?
    Nov 19 2006
    Vancouver
    Quote Originally Posted by MikeWasHere05 View Post
    Fuse?
    please excuse my ignorant, how can i check if the fuse is bad for the audio?
    97 QMT
    Nov 19 2006
    MMM
    I'm not sure which fuse it is exactly, but look it up in the owner manual. The fuse panel is located on the left side of the dash. Open the drivers door and look for a plastic cover on the side of the dash. There will be 2 or 3 spots where you can pry a little screw driver underneath it and pop it off. Replace the fuse and see if it works.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    are you sure you dont need to enter in you radio code?
    Nov 19 2006
    Vancouver
    Quote Originally Posted by 99blueb5 View Post
    hmm, the thing is that the audio display doesn't display anything like asking me to enter radio code or so.. it's like dead.. no lights on it at all
    97 QMT
    Mar 15 2008
    Connecticut
    This is an anti-theft feature. You need to get the security code and enter it in usin the buttons on the radio.
    Apr 22 2007
    Riverbank, Ca
    Does it say "SAFE" on the front? That would be it being in security mode. check your owners manual for fuses.
    Nov 19 2006
    Vancouver
    Quote Originally Posted by andyrew View Post
    nope , it doesnt say that, its just blank, nothing showing there, like it doesnt have power at all.
    97 QMT
    Nov 19 2006
    Vancouver
    anymore suggestion?
    97 QMT
    Oct 30 2006
    B8 A4 Avant 6spd
    Is it an aftermarket radio? A lot of aftermarket ones have the fuse on the back of the unit.
    -18 718 GTS
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    This happened exactly to me, had my car at a lot for a while. I thought I was screwed.
    You have to remove the radio, there will be a fuse in the back of the radio you can get at Autozone or something, just replace it and it will work. You will most likely need the radio code afterwards.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Nov 19 2006
    Vancouver
    Quote Originally Posted by Militant-Grunt View Post
    nope , it is stock audio
    97 QMT
    Nov 19 2006
    MMM
    I'm telling you, fuse.
    Sep 06 2007
    Bricktown, NJ
    so what if the radio is stuck? i mean, REALLY stuck. Removal tools don't work, either
