Results 1 to 4 of 4
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Car won't start(kinda)...
    So the car won't start without application of the throttle, the esp, abs and epc lights are all on and the car has no power whatsoever. Heres the code that came up:
    17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
    P1542 - 35-00 - -
    Anyone seen this before or know what it is(just a bad sensor or bad tb?)
    Thanks
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Car won't start(kinda)...
    bad tps?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Oct 06 2005
    Soccer mom car
    South
    Is there anyway to check if its the tb or the tps or something else? Thanks
    Dec 06 2007
    Calgary, AB, Canada
    Check to make sure the TPS is plugged in.
