Results 1 to 16 of 16
    Senior Member Two Rings Dompiece's Avatar
    Jul 17 2007
    San Diego
    Where can I buy Ecode Headlights?
    don't say AWE
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: Where can I buy Ecode Headlights?
    search user lowestA4 sometimes has something
    Established Member Two Rings CasaS4's Avatar
    Dec 14 2006
    Atlanta, Ga
    Call up Brian at Avalon. He's selling new e-codes that are significantly cheaper than the Valeo ones. They are made by a subsidiary of Hella and Avalon is the exclusive USA reseller for them.
    They are H7 lamps, but he also sells H7 55W HID kits (oem is D1S 35W, which isn't as bright and is much more expensive to replace bulbs). So for the price of Valeo e-codes (which are on galactic backorder), you could have these lamps plus 55W. Then you could sell your old lights as a kit or in parts. If you play your cards right, you might come out barely spending any money.
    Give him a ring: 303 400 3001. These lamps are on super-sale at the moment ($375/pair)!
    Jul 17 2007
    San Diego
    wow thats cheap!!! I am not sure I like the black in the middle...why don't they just make them like the valeo?
    Can anyone post a pic of what these look like on the car?
    Dec 14 2006
    Atlanta, Ga
    One of my friends is expecting his set to show up thursday. I might have pictures by Friday.
    As for the black center, I see where you are coming from. I think it will look pretty good when installed (esp. on dark colored cars). I believe they made it black based on feedback from A4 owners. They also make lamps for GTi's and other VAG cars.
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    Quote Originally Posted by Siggiepop View Post
    yes, lowest a4, jens is his name.
    as far as i know, ecodes are no longer being manufactured in the united states.
    jens lives in germany and gets the lights directly from a german audi dealer. i purchased a single ecode from him after an accident. the only source i know of now for brand new ecodes.
    Dec 14 2006
    Atlanta, Ga
    Quote Originally Posted by toaster View Post
    E-Codes were never made in the US.
    Jul 17 2007
    San Diego
    I wonder if Audi will order them from the factory?
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by CasaS4 View Post
    running a rebased xenon bulb in a non-xenon housing is not a good idea.
    Jul 17 2007
    San Diego
    ^heat? People have been debating that issue for a long time
    Jul 17 2007
    San Diego
    Avalon and LLTEK sell them. Has anyone tried to buy from them?
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Dompiece View Post
    no, not heat. the fact that a headlamp designed for a xenon bulb (be it reflector or projector) is intrinsically different than one designed for a halogen. look at how light is output with a xenon bulb vs halogen (filament).
    Senior Member Three Rings Sleepy 1's Avatar
    Apr 03 2007
    B6A4, B5 Passat, my girls B7A4
    Quote Originally Posted by ngng View Post
    Please explain in more detail? Thx!
    Dec 14 2006
    Atlanta, Ga
    I would agree with a reflector housing, not but with a projector housing. Changing the focal point (exact location of the light source) of the bulb in a reflector housing can create a less than ideal beam pattern and create glare for oncoming drivers. With a projector housing, the light bounces off of the rear elliptical reflector and is straightened by the lens. Any light that would be reflected in a a way that could produce glare is stopped by the cutoff shield. Having owned a B5 A4 with H7 e-codes and a B5 S4 with D2S e-codes, I can tell you that Valeo uses the exact same elliptical projector in their lamps, the only difference is what base and clip they weld on to the end. I have taken apart about 5 different projector headlights and compared them. I even have pictures comparing the <2005 (manuf. date) B5 e-codes to the inferior 2006+ e-codes. Unfortunately, I don't have pictures comparing the H7 vs D1S. That said, if you guys are interested, I will ask my buddy if I can take some pictures of his Avalon lights before he installs them. FWIW, He is a non-premium package A4, so he does not have HID lights.
    Pics always help:
    Apr 03 2007
    I would agree with a reflector housing, not but with a projector housing. Changing the focal point (exact location of the light source) of the bulb in a reflector housing can create a less than ideal beam pattern and create glare for oncoming drivers. With a projector housing, the light bounces off of the rear elliptical reflector and is straightened by the lens. Any light that would be reflected in a a way that could produce glare is stopped by the cutoff shield. Having owned a B5 A4 with H7 e-codes and a B5 S4 with D2S e-codes, I can tell you that Valeo uses the exact same elliptical projector in their lamps, the only difference is what base and clip they weld on to the end....
    So are you saying the projector for these is fine, and there are no heat problems or reduction in light or beam pattern with these housings?
    Senior Member Two Rings Corrado79's Avatar
    Jan 21 2007
    Los Angeles, CA
    Maybe, but they might run you $700/each. Dealer is not the way to go.
    2023 Audi RS7
    2022 Lincoln Navigator Reserve
    2019 MB E63S Wagon
    2016 Porsche 981 GT4
    1990 VW Corrado 16vG60
