Results 1 to 8 of 8
    Apr 19 2008
    ct
    someone please help boost problem
    i just bought a 2000 s4 the boost gauge reads 20 pounds when i first hit boost then the car wont go past 6 after a little while of driving the i did a boost leak and have no leaks and i dont have a check engine light either i changed the n75 still the same i dont no what else to check
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: someone please help boost problem
    So it will go up to 20 and as the RPM's climb the boost drops?
    Does it slowly drop down to 6 or instantly?
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Are you chipped? What other engine mods do you have.
    Apr 19 2008
    ct
    i think the car is chipped it have aftermarket diverter valves and samco tbb yes it goes to 20 pounds a couple of times then wont go past 6 after i hit full throttle a couple of times
    Apr 19 2008
    ct
    my mechanic thinks it might be the mass air flow meter i dont think that is the problem
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    if you can VAG it might find something hidden as your problem
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
    Dec 06 2007
    Calgary, AB, Canada
    Soft limp mode most likely caused by a boost deviation. Post some logs of VAG block 115.
    Jun 14 2007
    2000 S4
    Connecticut
    yeah unless you're stage 3 boost usually doesnt get so high otherwise the K03s may just blow out of your exhaust onto the street haha. like Jerbel said you probably have positive deviation code and your ECU is saying hell no!... so if you have VAG as in vag com log away
