    Mar 25 2008
    manchester CT
    maybe picking up a 2000 2.7t... questions
    Hey guys ,
    Well , i had a 2001 2.7t A6 before that was amazing , loved everything about it even with it being a auto. I am hunting for a new car again and came across a 2000 2.7t manual that needs work. So i have a few questions on what i am getting into .
    Let me start by saying i am pretty good with turning a wrench and have a good set of tools to go with it. Now on to what is wrong with the car .
    The car is a 2000 with about 165k on it . Timing belt snapped ....
    so correct me if i am wrong , but i heard i have to pull the motor to pull the heads. I am figuring i can pull the motor put it on the stand and pull the heads. Then replace the valves and seals, maybe get a valve job or just lap the new valves in good. Then while the motor is out and heads are off , hone and re ring it , new pumps and bearings . put it back together and be done.
    I know that sounds easy the way i wrote it and didnt put the price of valves and other parts , but i also own a parts store , so parts will be at cost( they are still pricey ) . i would like to look for some newer turbos to put on it while i am there , but just want to hear your guys thoughts and what else i will be looking at with this car.
    the help would be great . oh and i maybe getting the car for 1k , so that is good , just want to hear the pointers in here. thanks guys .
    - Herby53
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: maybe picking up a 2000 2.7t... questions
    upgrade to k04 turbos, new software, fueling kit, exhaust -- mmmmm, nice project car.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Mar 25 2008
    manchester CT
    man thing is to get it running so i can drive it . if i find turbos for a cheap price , i would swap them . so does anyone know if i can pull the heads with the motor in , or do i have to pull it out ? been reading some tech writeups on audiworld , doesnt sound like anything i cannt handel out side of the cam tool. but have a friend that can lend me that tool
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    i'm not a mechanic or anything like that but i think you do have to pull the motor
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
    Sep 20 2006
    Burnaby, BC, Canada
    if i were you i'd pull the motor. there's barely any room in there to get the back bolts out for the heads, and it's just a general pain in the ass
