Results 1 to 3 of 3
Thread: CLutch problem
    In Limbo Two Rings
    Jan 05 2008
    2002 audi A4,
    Jersey
    CLutch problem
    Can i use this clutch with my OEM stock flywheel? Thanks
    http://www.mjmautohaus.com/catalog/p...roducts_id=664
    Dec 25 2004
    Earth
    Re: CLutch problem
    Yes, but the picture is not the actual Spec Stage II clutch....
    http://www.specclutch.com/csproducts.html
    Pictured is the stage III+...
    Jun 30 2007
    Raleigh, NC
    Re: CLutch problem
    apparently the spec is a shitty kit. AWE is a good cheap solution, my stg 3 is holding up very nicely -- it'll get put through its paces for real by the end of next month.
    southbend is another great clutch, and they resurface your flywheel for free if you don't mind waiting
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
