Results 1 to 8 of 8
    Mar 23 2008
    philippines
    leak in drivers side
    hey guys, already searched but i couldn't find anything conclusive hope u guys can help!
    got in to the car this morning to wet carpet in the driver's side floor. the leak seems to have come from the area beside the hood latch under the steering wheel. i pooped the hood and found a puddle under the battery. is there a drain somewhere that is clogged? i just had my car painted, could it be the painter didn't put something back?
    Mar 23 2008
    philippines
    Re: leak in drivers side
    no ideas?
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    If you remove the battery, you will find the drain under it blocked with leaves and stuff. Clear it and hopefully problem solved
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    check the rubber grommet for the hood cable...mine leaked a bit sincew it wasnt in place properly
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Mar 23 2008
    philippines
    alright thanks guys! will give it a look 2mrw morning. hopefully those are the sources so i can stop my car from flooding.
    Active Member Two Rings Monk's Avatar
    Dec 13 2007
    98' A4 1.8TqM (AEB)
    Philippines
    There are two drains - one under the batt. like Mawhitey said, & another one near the brake master cylinder. Pull out the funnel shaped rubber grommets for thorough cleaning. Gunk can sometimes build-up, w/c can lead to flodding.
    B5 1.8TqM (AEB) :: GTRS :: Mika E-PROM :: RC 550cc :: Walbro 255LPH :: 3'' Inlet & MAF housing :: TS MBC :: BaileyMS DV :: EvoMS FMIC :: Phenolic spacer :: ATP x-mani :: Supersprint Testpipe & Exhaust :: Innovate XD-16 w/ LC-1 :: Southbend OFE stg.3 :: Boxster 4pots :: etc.
    Sep 13 2007
    the box that the ecu is in may not be seated right if this is so you will have a big leak there and another place I would look is at the weather strip on the door jamb when I had my truck repainted they did not put the weather stripping back in all the way and it leaked all over the floor hope this info helps
    Mar 23 2008
    philippines
    thanks for the replies guys. kinda lost though (sorry ive only had my car for a couple of weeks) can anyone point me to where these are? like a picture maybe? i know where the drain under the battery is, not so sure about the weather strip on the door jamb and the funnel shaped rubber grommets. pardon my ignorance haha!
