Results 1 to 14 of 14
Thread: jerky shifter??
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    jerky shifter??
    My shifter seems to be kinda jerky. When im at a complete stop and take off nice and smooth the shifter looks as if it tightens up and stays that way, and when I let off the gas it gets loose and will continue to do this (tighten up) everytime I get on the gas. Is it the tranny mounts? The car shifts smooth with no grinding.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: jerky shifter??
    Mine does that too. From what I understand, its normal. If you're meticulous about it, get the JHM tranny makeover.
    Active Member Four Rings
    Jul 17 2004
    Re: jerky shifter??
    If you're just talking about shifter movement when going on-off gas, that's normal. A JHM won't cure that...
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Nov 07 2007
    New York City
    Re: jerky shifter??
    yeah its when I get on the gas the shifter gets tight and wont jerk and when i let off completely it will jerk slightly and stay still untill I get back on the gas.
    Registered Member Two Rings WaySloS4's Avatar
    Mar 13 2007
    '04 Black S4
    Toledo, OH
    Re: jerky shifter??
    mine as well.... i just try and ignore it
    '04 S4.... stock for now
    '80 Trans Am G-Machine project.... in pieces all over my garage
    '01 S4 Stage 2+.... gone and missed
    Nov 07 2007
    New York City
    Re: jerky shifter??
    alright it seems to be normal then..I guess im going to have to just do the same and ingore it to..and thank god its not a problem im kinda broke right now loll after just buying the s
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Re: jerky shifter??
    will Tranny Stabilizer help it some what?
    is should minimize movement b/w the engine and the tranny, right?
    Jan 28 2005
    02 S4
    soCALI
    Re: jerky shifter??
    check the condition of your motor and transmission mounts. sounds like they are worn. upgrading/replacing them will help, but probably won't get rid of it completely. A little movement is normal. snub mount and Drive train stabilizer bar will help too if you don't have them.
    Apr 05 2007
    Re: jerky shifter??
    mine does that with new 034 motor mounts, rs4 trans mounts, rear diff bushings, snub mount. I know i need a new rear diff mount but that won't really affect the shifter shake. it's normal..
    Dec 06 2007
    Calgary, AB, Canada
    Re: jerky shifter??
    Quote Originally Posted by h3lp_c0mput3r View Post
    2nd.
    Drivetrain stabilizer bar especially helps in this regard.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: jerky shifter??
    its fine, i have 034 m/t mounts and teh jhm tranny rebuild and short throw and it always does it doesnt bother me its normal, its telling u its in gear with ur gas in pretty much....live with it lol dont have to buy anything for it evein if u get a DTS it will still be the same
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: jerky shifter??
    Consider it a feature.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: jerky shifter??
    people say to get SNUB mount, motor and tranny mounts, REAR diff mount which helps the most and DTS, all can be found @ 034 except for DTS i think, get AWE or ASP! I have all except the rear diff mount from 034 and DTS which i plan on doing with h sport sway bar kit during the summerrr
    Jun 14 2007
    2000 S4
    Connecticut
    Re: jerky shifter??
    Quote Originally Posted by Dimcorner View Post
    lol
