Results 1 to 17 of 17
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    ECU compatibility???
    Which ecu box is compatible with M-box?
    I have seen a post with all the good info, I can't find it!
    can someone direct me to that post, or can you tell me what else I could use?
    I need new ECU and I can't find any m-box ecu here or on ebay!!!
    Please help!!!
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: ECU compatibility???
    any the 02 6 speed would work. forgot the letter though.
    Dec 06 2007
    Calgary, AB, Canada
    T box
    Apr 01 2008
    Massachusetts
    what if I can't find any M or T box?
    My car has been sitting in a shop for a couple of weeks, I really need a working ECU!!!
    I was going to get a chiped ecu, but I can't find Neither!!!
    I'm in big trouble...=/
    Dec 06 2007
    Calgary, AB, Canada
    I hear mthomas may have a chipped ECU for sale....
    Apr 01 2008
    Massachusetts
    Will A-box work with M-box, 2001.5, 6-speed?
    Mar 18 2008
    Chicago, IL
    I bookmarked this 'cause I use it so much.
    http://www.audizine.com/forum/showth...nterchangeable
    Mar 14 2007
    MN
    It will work regardless, but if it isnt the right one it will just set off your epc light which just takes a few seconds to reprogram. I have done that in the past.
    Apr 01 2008
    Massachusetts
    Thank you so much MavSBM!!!
    That's what I was looking for!!!
    I'm going to bookmark that, too!
    So for M-box, I can use either T(2002) or H(2001) box, but not A(2000) box?
    Mar 14 2007
    MN
    let me know if you want mine i have a 2002 6spd and i just had to recode the cluster when I got it. I would check for you, but my car is getting its ko4's installed right now!!
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    i have a 2000 s4 and it had a-box before i ran stage 3. now its got M-box.. works great, after recoding cluster
    Apr 01 2008
    Massachusetts
    So A and M are compatible???
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by mike's machine View Post
    if you put an a-box in your car your cluster will throw a cel until you recode it to match the new ecu, otherwise it would work. someone please correct me if im wrong.. but this is what i did but going from a to m not the reverse
    Apr 01 2008
    Massachusetts
    So A to M is possible but no guarantee from M to A?
    Hmm...
    Dec 06 2007
    Calgary, AB, Canada
    You can go either way, but you need more than a cluster recode. You also need to swap in the correct MAF sensor for whichever ECU you're using. A box requires Bosch MAF and M/T boxes require Hitachi.
    Apr 01 2008
    Massachusetts
    true, thank you for the answer!!!
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    ygpm
