Results 1 to 7 of 7
Thread: stock s4 boost?
    Jan 17 2008
    louisville
    stock s4 boost?
    I've heard several places that they make 9lbs. I've always thought mine was a little slow, but it runs just fine on the stock program. I can hear no boost leaks or anything. But when I'm in full boost I'm only at 5 lbs. vaccum is at 21 while at idle. when i turn on my apr program I read 16lbs so i dont think its leaking. weird.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: stock s4 boost?
    is this a question or a statement? STFA dude.
    Jan 17 2008
    louisville
    Re: stock s4 boost?
    sorry, i guess a question. is that normal to be boosting 5lbs? could there be a problem here
    Feb 17 2004
    Sterling, VA
    Re: stock s4 boost?
    8.5-9Psi is stock boost. 5Psi usually means that the car went into limp mode to protect itself. Pehaps you have a boost leak or faulty N75 valve.
    Limp mode will occur if you request alot more boost than the ECU can handle or if the N75 is disconnected (or failed).
    Have you checked for any codes yet? Now's the time to do so....
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jan 17 2008
    louisville
    Re: stock s4 boost?
    ill check tom. why would it run at 16lbs when switched then?
    Dec 06 2007
    Calgary, AB, Canada
    Re: stock s4 boost?
    Quote Originally Posted by Daft View Post
    Limp mode will occur if you request alot more boost than the ECU can handle.
    What do you mean by that, Brett?
    If the ECU was in hard limp mode, then switching programs wouldn't make a difference.
    It's possible that you hit soft limp mode.
    Like Daft said, check for codes.
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    Re: stock s4 boost?
    have you ever done the leak check ?
    check the ttb also vag it
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
