Results 1 to 12 of 12
    Senior Member Two Rings skizsam's Avatar
    Apr 28 2007
    Fairfield, CT
    Help! car vibrating- coilpack?
    So I was at a light about 0.25 miles from home. All of a sudden my rpm's start to dip and the car starts vibrating. When the light turned green, I gave it gas and the check engine light started to blink on and off. I was able to drive home and pull these codes ( P0402 and P0011 were already there before this issues):
    Well 1st thing tomorrow morning I'm off the the VW dealership down the street to pick up a coil pack? Any other suggestions. My car seems to be un-drivable.
    Someone please respond so I can atleast sleep well tonight! =) I guess I should have expected this to happen since it's posted all over the place
    Codes:
    Monday,28,April,2008,20:23:02:11955
    VAG-COM Version: Release 704.1
    Address 01: Engine
    Control Module Part Number:
    Component and/or Version:
    Software Coding:
    Work Shop Code:
    4 Faults Found:
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 002 - Lower Limit Exceeded - Intermittent
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 002 - Lower Limit Exceeded - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16688 - Cylinder 4: Misfire Detected
    P0304 - 001 - Upper Limit Exceeded
    Readiness: N/A
    2002 1.8T A4QM
    APR stage 1 | SouthBend Stage 1 | Reiger | BBS | Remus | AWE Boost gauge
    Apr 28 2007
    Fairfield, CT
    Re: Help! car vibrating- coilpack?
    I think this confirms what going on:
    http://www.audizine.com/forum/showth...ilpack+failure
    2002 1.8T A4QM
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Its a coilpack on cyl 4
    Apr 28 2007
    Fairfield, CT
    Bingo. Went to the VW dealership this am. Got a coilpack for $45.
    I replaced coilpack 4 (one in the back) and off to work I went.
    Order 3 new ones in a few minutes online.
    2002 1.8T A4QM
    Jan 10 2007
    VA
    You hear about CPs going bad all the time, but it still scares everyone the first time it happens as it really makes the car run like crap.
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Bro my number 1 and 4 went on me last saturday afternoon. Ive got 2 on order so my car will sit till this Friday. But im going to go to the local dealer and buy 2 more and keep them in my Trunk in the event that 2 and 3 decide to check out.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by b6onboost View Post
    My first coilpack blew in the shop when I got flashed with crappy Revo junk.
    On my own, Two coils blew on me like 3 weeks ago. I knew right away what it was so I plugged in the vag com and figured out what Cyl's they were and took my moms nissan to VW and popped em in 10 mins later
    I wasnt so shocked just dissapointed cause I had an appointment so I was rushing
    Jan 10 2007
    VA
    ^ My point was that even though its a cheap, easy fix, it still makes the car run crappy enough to really freak people out...sometimes even if they are familiar with CPs being a common problem.
    Sep 24 2007
    Woodbridge, Ontario
    Yeah fair enough. I panicked a bit when I blew one on saturday.
    Apr 28 2007
    Fairfield, CT
    That's exactly what happened
    2002 1.8T A4QM
    Established Member Two Rings itsjeo's Avatar
    Feb 03 2008
    04 a4 3.0q 6spd
    City of Angels
    haha two in two weeks for me!
    Apr 28 2007
    Fairfield, CT
    What timing.... I just got the news ones today and on my way home from work the second one went!
    I ordered them from: www.1stvwparts.com (which is www.auburnvw.com)
    Each were $22.98 and $10 total for shipping.. Part number 06B-905-115-R.
    Sure beat the $45 at my local dealer
    2002 1.8T A4QM
