Results 1 to 11 of 11
    Feb 03 2008
    PA
    Car wont start after DP install!?
    Well took my buddy and i all weekend to do my piggie pipes, about 10 hrs. Besides the down pipes being a bitch, i was all excited to hear how it sounded and i went to start the car up and it wouldnt even turnover!! I was too pissed off to look it over so i just took it to the mechanic and had him check all fuses and they were all good. So he tried to pop start my starter and it fired right up. So its definetly something to do with the wiring to the starter, right??
    Have any of you guys had this problem???
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Car wont start after DP install!?
    Quote Originally Posted by khop2131 View Post
    am i a noob since i have no idea what this means? ^
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    hammer or wrench to it or push start the car. a bad engine speed sensor will not let the car start but i believe it is on the top of the tranny. wish i could help you
    Feb 03 2008
    PA
    This would of had to happen when i was getting the down pipes out or putting them back in. I didnt see any other wires around the down pipes. Is there???
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    when you say pop start the starter, you mean he supplied 12v to the exciter wire of the starter? if so, how did he get access to it?
    or do you mean he pop started it as in he got it rolling then popped the clutch in to start the car?
    its probably unrelated to the DP install ... but im not sure what you guys messed with. think starter motor or ignition switch.
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Feb 03 2008
    PA
    Well we got lookin at it today and found that it is the wire runnin from the starter to the ignition. Theres no juice runnin to that wire, so i must have pinched it of cut it off.
    Is there a fused link to any of the wires that run to the starter??
    Dec 06 2007
    Calgary, AB, Canada
    ignition switch and clutch switch are in the circuit. There is no fused link AFAIK.
    Feb 03 2008
    PA
    alright that helps me out, thank you!!
    Is there a wiring diagram of the starter??
    Dec 06 2007
    Calgary, AB, Canada
    I've had a look at the wiring diagram a few times, and have yet to make sense of it.
    Feb 03 2008
    PA
    o really, where did you find the diagram at??
    Dec 06 2007
    Calgary, AB, Canada
    the Bentley manual
