    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    BBS wheels in Mercedes fitment for Audi B6?
    So I have a chance to get a set of BBS RK2s for really cheap, with just a bit of curbing on the rims. Would I have to have the bolt holes drilled to accept a different size bolt for the Audi, or are these going to just maybe need some hubcentric rings? I searched, but all I came up with was people asking about stock Mercedes wheels on older Audis.
    -Tim
    Jun 14 2005
    Anaheim, CA
    Re: BBS wheels in Mercedes fitment for Audi B6?
    Mercedes centerbore is 66.6, Audi is 57.1 You will need to bore out the center.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    The wheel should have a ring in it already, we'd need to know the bore of the wheel to get it down to what you need. The part number off the back of the wheel would help as well.
    Jun 14 2005
    Anaheim, CA
    Woops, misread... i thought your putting audi wheels onto a mercedes. So if your putting Mercedes wheel onto an Audi then what you need is a hub centric ring.
    -Charles@VMRWheels
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I think BBS makes most of their wheels with large CB's so that they will fit everything. Thats why they sell their PFS kit.
