Results 1 to 24 of 24
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Those of you that have rebuilt your trans, a few Qs inside..
    So i started to tear down my trans today, and have a few Qs. The trans is broken apart, but doesn't want to fully break apart so i can see what all im going to need before i put a order in to jay. The trans is about 1/2 apart in the middle, but im afraid to really rip on it apart. Is there some secret technique to breaking it down? Or i am good to get physical with it? Just don't want to break anything quite yet, haha.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Dec 06 2007
    Calgary, AB, Canada
    Re: Those of you that have rebuilt your trans, a few Qs inside..
    There is a bearing that is press fit in between the 2 cases. You should either use a steering wheel puller to pull the cases apart, or CAREFULLY use some sort of pry bar, working your way around the case. It does take a far amount of force, as it's pressed on there quite tightly.
    Dec 17 2004
    US
    So, worked on a it a little bit more tonight. Still, case is not apart. I have it about 1in apart, but doesnt want to fully disengaged. Is there something more to take apart? Any tips from people that have done this?
    I used the pry bar, but just worried about getting to forceful with it.
    Dec 06 2007
    Calgary, AB, Canada
    If you've got it separated by an inch, you're almost there. It takes a LOT of force. Just be careful not to damage the sealing surface too much.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    yea bro its a bitch, you can put shims in there and keep adding until its out completly or what i did was 2 crowbars on each end and it came out
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Dec 17 2004
    US
    Thanks guys, going to try that tonight.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    so if its this hard to separate how hard is it gonna be to get it bolted back together??
    Dec 17 2004
    US
    Well find out..:)
    Dec 06 2007
    Calgary, AB, Canada
    Pretty damn easy actually. You just seat the pressure fit bearing before putting the 2 cases back together. It bolts right up without any problems at all.
    Jun 15 2007
    Quote Originally Posted by ThirdStrike View Post
    going back together is easier
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Dec 17 2004
    US
    Do i need to be careful for any bearing when i break it open? i know there are some and im NOT loosing any if i can help it.
    Dec 17 2004
    US
    Alright, got the case off. Important Q, how many bearings should be there when it comes apart? Someone please 12? Thats all i could find. Im not going to go any farther till i get the video. 1st and 2nd gear are shot, and don't look good. All the others look good as far as i can see.
    For you guys that have done the rebuild, what was the hardest part?
    Any special tools? I know snap ring pliers are pretty important.
    Dec 06 2007
    Calgary, AB, Canada
    GOOD Snap ring pliers, a dentist style pick set, a hydraulic press....that should about cover the important tools list.
    And there should be 23 little bearings. You shouldn't have taken out that shaft without watching the video first....now you'll have to buy new bearings if you can't find them all.
    Dec 17 2004
    US
    What? I took it apart in a specific spot so i didnt loose any of them. And i know only 12 cam out. Ill have to go on a search.
    Dec 06 2007
    Calgary, AB, Canada
    There's a trick to keeping the bearings from falling out inside the tranny...make sure you watch the video all the way through before proceeding.
    Jun 15 2007
    Quote Originally Posted by The_Jerbel View Post
    truei didnt use the video since he didnt make it at the time but its teh rod (with gears on the end) that is slid inside the hollow shaft (the shaft with the 1-2 gears) and once opened 23 tiny peaces of bearing will be there....good luck ab18
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    I removed the Torsen differential housing on mine last night. Was too afraid to go further without the video. Not to mention the smell of gear oil makes me really nauseous. The fumes aren't toxic, right? With luck UPS will have the rebuild kit on my doorstep tomorrow.
    Past - '01.5 S4, APR Stage III
    Dec 06 2007
    Calgary, AB, Canada
    If you guys are waiting on the video, and if you want to call me, I can help out with some of your questions. 403-690-7135
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by AMC83189 View Post
    The trick is to use a hose clamp and put it on the inner rod right where it comes out of the hollow shaft. That way the inner rod won't slide down through the hollow shaft and release all its bearings into the black abyss of the tranny.
    Jun 15 2007
    i kno the trick i saw the video he sent it to me after i rebuilt it and saw some of it...i should have done that lol
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Dec 06 2007
    Calgary, AB, Canada
    Sorry, I was actually telling AB18 the trick by building on what you posted.
    Dec 17 2004
    US
    Im just going to wait untill i get the video. Its just all to confusing doing it all without a vid or bently. I only have 12 of those bearings, and im going to find them all if its the last thing i do. Where else could they have gone? Thanks for all the help.
    Jun 15 2007
    Quote Originally Posted by AB18 View Post
    12 is no good lol
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Dec 17 2004
    US
    Your not a kidding, where could have they gone if they didnt come out when i broke it apart?
