Results 1 to 23 of 23
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    question about a tining belt service
    Hi i guys i was wondering what is the symptom of a bad timing belt because i picked up my car about 2 month ago with 120k and i ask the dealer if the previous owner had a timing belt change and he sed he dont know so do you guys know what the symptom to a bad timing belt is? Let me know thanks oh the car is a 2000 audi s4.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Re: question about a tining belt service
    If it made it that long it most likely has had it replaced. They mostly will not go more than 80-90K miles.
    And there are not any symptoms that I know of. It just breaks and then you get to rebuild the engine.
    Josh
    Jan 29 2007
    08 S4 00 S4
    MD
    Most of the belts I've done have all looked fine when removed, even at higher mileage, but they are most likely weakend internally. Make sure the rollers and waterpump are also replaced, so get a complete kit if you are doing it yourself.
    Mar 11 2008
    san diego ca
    thanks i think im going to change it again to be on the safe side i was just wondering what kind of symptom there was because my car is throwing code p1557 Charge Pressure Control: Positive Deviation any idea what that is? The search button didnt really help me.
    Jan 29 2007
    08 S4 00 S4
    MD
    You have a boost leak somewhere. You need to pressure test.
    Dec 06 2007
    Calgary, AB, Canada
    That code means that your wastegates most likely aren't functioning properly. Your car is boosting higher than the ECU is requesting. The cause is probably either a bad N75 valve, bad WG lines, or a WG that isn't opening like it should.
    Mar 11 2008
    san diego ca
    oh thanks because i was trying alot to find out what that was.
    Mar 14 2007
    Phoenix Arizona
    Hopefully it's not a bad wastegate... that would suck.
    Josh
    Jan 29 2007
    08 S4 00 S4
    MD
    Or a wastegate line..that would suck..But wouldn't he be seeing "charge pressure exceeded" codes?
    Junior Member Two Rings
    Apr 11 2008
    2007 Audi RS4
    Charleston, SC
    Odds are it's a boost leak. I had an intercooler hose off and was throwing the same code. Do you have any symptoms or is it just throwing the code?
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by mholme View Post
    He did, the actual code looks like this:
    That means that the boost pressure is positively deviating from what the ECU is requesting. A negative deviation code usually means that there is a boost leak somewhere.
    I would pressure test just to be safe, but I'm betting that it's a bum N75 or associated lines.
    Jan 29 2007
    08 S4 00 S4
    MD
    O I C..I was talkin about 17963 - Charge Pressure: Maximum Limit Exceeded. I thought that one was the one more commonly associated with wastegate/N75 issues.
    Mar 11 2008
    san diego ca
    ok i will fet pressure test and let you guys know the results and my symptoms are when im sitting at the light sometime the rpm would be jumping up and down like its gonna stall out. What if it is a waste gate what would i have to do to fix the problem?
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Quote Originally Posted by ThePaintballGuy View Post
    Josh
    I did the first TB job for my car at 101k miles. Belt looked great still. So your statement is not exactly true.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by xx_s4quattro_xx View Post
    It would be easier to diagnose the problem if I had some logs.
    It sounds like it could be a boost leak, like a leaky WG line or something.
    If it's a bad WG you'd have to pull the turbo. Cross that bridge when/if you come to it.
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by Jsmooth65 View Post
    You can't judge the condition of the TB just by looking at it. Sometimes it gets weakened over time even if it looks good. All of a sudden a couple of teeth strip off and there go your valves.
    Mar 11 2008
    san diego ca
    ok here is a vag copy i thought a timing belt change would help but i guess not im still going to get that done but check this out any ideas Address 01: Engine
    Part No: 8D0 907 551 A
    Component: 2.7l V6/5VT G 0003
    Coding: 06611
    Shop #: WSC 06325
    2 Faults Found:
    16487 - Mass Air Flow Sensor (G70): Signal too High
    P0103 - 35-10 - - - Intermittent
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Part No: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D10
    No fault code found.
    Address 08: Auto HVAC
    Part No: 8D0 820 043 P
    Component: A4 KLIMAAUTOMAT D56
    Coding: 00160
    Shop #: WSC 06325
    Skipping Address 15-Airbags
    Address 17: Instruments
    Part No: 8D0 920 980 DX
    Component: B5-KOMBIINSTR. VDO D13
    Coding: 02264
    Shop #: WSC 22197
    2 Faults Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    31-10 - Open or Short to Ground -
    Intermittent
    01311 - Information Data Bus
    37-10 - Faulty - Intermittent
    Address 35: Centr. Locks
    Part No: 8L0 862 257 N
    Component: CV-Pump D11
    Coding: 16232
    Shop #: WSC 06325
    4 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely
    Leak)
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 37: Navigation
    Part No: 4B0 919 887 A
    Component: Navigation 0001
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 45: Inter. Monitor
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06325
    1 Fault Found:
    01380 - Alarm triggered by Anti-Theft Sensor; Rear
    Left
    35-00 - -
    Address 55: Xenon Range
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D003
    Coding: 00012
    Shop #: WSC 06325
    Address 56: Radio
    Part No: 8D0 035 195 A
    Component: Radio D00
    Coding: 00115
    Shop #: WSC 06325
    1 Fault Found:
    00-00 - -
    End
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    I dont know that much about these cars yet, but from what ive read Jerbel is most likely correct. As far as the Tb is concerned...there usually arent any symptoms before it goes. Sometimes the belts look brand new(not even a tooth missing) even after theyve skipped teeth and destroyed an engine. Most of the time theyll just stretch under high tension and cause the damage. The best way to fight this is to put a new one on.
    Good luck with fixing the codes.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Dec 06 2007
    Calgary, AB, Canada
    Looks like the MAF sensor might also be toasty. The ignition switch as well.
    Clear all codes and see which ones come back. It's obvious you haven't cleared codes in a while...
    Mar 11 2008
    san diego ca
    the maf sensor is like 2 month old and i have a turbo timer hooked would that be messing with the ignition switch?
    Dec 06 2007
    Calgary, AB, Canada
    Well the MAF code is probably old then.
    The turbo timer could possibly throwing the code for the ignition switch.
    I would just clear all the codes and see what comes up in the next few days.
    Mar 11 2008
    san diego ca
    thanks jerbel ill get this pressure test i setup a appointment with jeff moss from torque factory he sound like a good guy. How much does a n75 valve run for? and is it hard to install i think im just gonna change that too.
    Dec 06 2007
    Calgary, AB, Canada
    It's like $85. Changing it is a good idea.
