Results 1 to 22 of 22
    Forum Moderator Four Rings docurley's Avatar
    UK London
    S4/RS4 brakes on to an A4
    Well lots of people ask this question and load ask it after they buy the brakes so as I'm doing the conversion with RS4 brakes (they mount the same as the S4) I thought I would do a what’s needed and what wont work thread.
    Q: Will S4 or RS4 Callipers mount on to the A4 Hub's?
    A: No
    Q: Can you get them to fit?
    A: Yes
    Now you want to know how and I hope to have the answer with some info of what you need to do.
    First of there are no current carriers on the market to allow them to mount on the A4 hubs so you need the S4 hub's to make this work with the drive shafts.
    Now if you are FWD will make things very easy for you guys as your flange on your gearbox is a 108mm flange where as on the Quattro gearbox the flanges are only 100mm which means the S4 drive shafts will not fit. Before you think all is lost there is a way round this (pain in the arse but you do have an option). Basically you need to get hold of some FWD flanges which will just pop out with a crow bar (So I'm told).
    Then all you need do is swap the flanges over from your Quattro gear box with the FWD flanges then the S4 drive shafts should all line up and bolt together.
    I will be confirming all this at the weekend as Siena and me will be doing this at the week end as I have a almost dead CV joint and a couple of RS4 legs sitting around ready for the swap with all the RS4 brakes to match.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: S4/RS4 brakes on to an A4
    The S4/RS4 hubs have different wheel bearings too, don't they?
    Are you swapping in the whole aluminum upright? That is what I would like to do to reduce unsprung weight.
    Jim
    I Do Werk.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Flanges packed ready to go ;-)
    And to confirm they will lever out of the 'box.
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    UK London
    Sweet myman just need Siena to pick me up the four calliper brake bolts and project RS4 brake should be all go and then at a later date RS6/RS4 (B7) Callipers will be added.
    UK London
    Quote Originally Posted by onemoremile View Post
    Are you swapping in the whole aluminium upright? That is what I would like to do to reduce unsprung weight.
    I have the whole thing and yes the uprights are ally and ready just to bolt in after I swap the flanges, not sure about the wheel bearings and bothered as I will be swapping the lot in but a nice bit of info for every one.
    UK London
    Well I got my FWD flanges for my 1.8TQ and they fit the RS4 drive shafts perfectly, so on Saturday it should only be a case of popping my flanges out and pushing these in.
    RS4 ARB
    RS4 leg and as you can see it's all Ally
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Good stuff, Doc. The bolts will be delivered tomorrow morning.
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    Jerks and your readily available rs4 parts, i guess there are some benefits to living in the UK
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    UK London
    Quote Originally Posted by Siena View Post
    Things look like this will be a straight swap
    UK London
    Quote Originally Posted by SilverB5A4 View Post
    Oh yes and not forgetting the £ to the $ rate makes every thing half price.
    Jan 20 2005
    99 AJL TQS
    UK
    Quote Originally Posted by docurley View Post
    Lets hope it was easier than my conversion,lol
    -Mark -
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Come move to America, youll be 2x richer
    Looks like a good start though, hope everything works out in your benefit, would like to see the final pics of this.
    (Ka-La-Bre-Ah)
    UK London
    Quote Originally Posted by Calabria View Post
    Not quite true as I would have to get a job out there and have to pay for thing with $'s so right now it works to be in the UK.
    I will take lot of pics of what I do and show the two legs together so people can see the difference.
    Oct 30 2006
    B8 A4 Avant 6spd
    I just did the same conversion as you, except S4's and not RS4's. I needed to change to S4 uprights, and get Audi A4 2.8 axles. (Got new wheels bearings and upper controls arms while I was at it.)
    -18 718 GTS
    UK London
    Ok just got home at 11:30pm and I'm beat. I have completed the conversion and I have to say they are far better than A4 units testing them with a 2.5 hrs drive home from Siena house.
    I will explain more if anyone’s interested but for the mean time here are so pics.
    Oct 30 2006
    B8 A4 Avant 6spd
    How much did the Rs4 calipers run you?
    -18 718 GTS
    UK London
    Quote Originally Posted by Militant-Grunt View Post
    This was part of my original purchase of the RS4 shell I bought 2 years ago, so you say no cost.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    ^^^ Also known as home of the S8 swap
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Jan 20 2005
    99 AJL TQS
    UK
    Did you swap the Box in too??
    Or just flanges and shafts?
    -Mark -
    Jan 09 2008
    United Kingdom
    Quote Originally Posted by Mawhitey View Post
    Just flanges and shafts.
    Feb 15 2007
    marimont
    Pretty sure s4 calipers bolt to the 01 b5 a4 only.
    Jan 09 2008
    United Kingdom
    Quote Originally Posted by solowb5 View Post
    Not a chance.
    Lug spacings are completely different.
