Results 1 to 7 of 7
Thread: Dead Spot
    Apr 17 2008
    Central, NY
    Dead Spot
    I just purchased an '06 A4 (automatic) with 22,000 miles on it. Love the car but notice there seems to be a dead spot at 1200 rpms. If I'm starting from a stop, say driving through town, the car accelerates/shifts normal until it hits 1200 rpms then there is a hesitation say until you get pass 1400 then the car takes off. Its then perfect at any other speed/condition after that. Any suggestion on what could be causing it?
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: Dead Spot
    Your feeling slight turbo lag that is more noticeable in the automatic version of the 2.0t
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Apr 17 2008
    Central, NY
    Re: Dead Spot
    Any fixes for this other than quicker acceleration?
    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    Re: Dead Spot
    apr
    2010 ibis white s4
    CTS Turbo intake
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: Dead Spot
    my car is pretty similar to yours and i have the same thing when turning off of my street from a stop. its turbo lag. even a chip isnt really going to fix that. blame the transmission- a manual would have made things better.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Oct 01 2007
    Location, Location, Location
    Re: Dead Spot
    Quote Originally Posted by RedS-line View Post
    Yeap, had the same problem, now i've just gotten used to it.
    Apr 17 2008
    Central, NY
    Re: Dead Spot
    Thanks, its my first audi, so I feel better knowing that this is normal behavior and that there is not something wrong with the car
