Results 1 to 11 of 11
Thread: Coil Packs?
    Established Member Two Rings Quattro_USP's Avatar
    Apr 24 2008
    Kansas City, MO
    Coil Packs?
    Just replaced plugs and now have a CEL with rough idle and what feels like missing. I am almost sure it's the coil packs (maybe I damaged them when I pulled the plugs) but I don't want to spend the money for new ones and risk it not being that. I need some opinions or experiences.
    '04 B6 A4 1.8T
    Thanks
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    Re: Coil Packs?
    If you're able to, (or if you even have the software), do a scan.
    What kind of plugs did you use?
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Coil Packs?
    i just checked my coils on my car today..
    start ur car, and starting from ur 1st coilpack, remove it, and notice how the engine sounds, if the sound drops or it starts shaking, it means that coil is good, so just pop it back into place and move onto the 2nd .. etc
    if a coil is bad, ur engine will sound the same as always, meaning nothing will change when u remove that coil ..
    Apr 24 2008
    Kansas City, MO
    Re: Coil Packs?
    I don't have the VAG software, I was debating on buying it but $250 is alot and I'm scared of how complicated it sounds. I used NGK BKR6E plugs.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Coil Packs?
    Quote Originally Posted by Quattro_USP View Post
    '04 B6 A4 1.8T
    Thanks
    I had the same thing happen. But I knew right away which coilpack it was because it was quite a bit older than the others.
    Yes youre going to have to do the unplugging deal that was mentioned if you dont have vag software
    Registered Member Two Rings Laconvail's Avatar
    Oct 28 2006
    2002 A4 1.8TQM, 2005 GSXR 600
    North Carolina
    Re: Coil Packs?
    Quote Originally Posted by GtiRSmiley View Post
    I would definitely just unplug them one at a time. Pulling them up sounds like a bad idea.
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Coil Packs?
    Quote Originally Posted by Laconvail View Post
    http://forums.audiworld.com/a4gen2/msgs/1003672.phtml
    I followed this guide.
    Established Member Two Rings w3fl3x's Avatar
    Mar 04 2007
    02 A4, 95 M, 95 325i
    ...in the puddle... WA
    Re: Coil Packs?
    That's a very good write up with pics.
    Oct 28 2006
    North Carolina
    Re: Coil Packs?
    Still say its a better idea to just unplug them. Pulling them up while they are operational seems like a good way to damage something or get the crap shocked out of you. Of course either way, removing or unplugging, would work.
    Jan 10 2007
    VA
    Re: Coil Packs?
    It's a CP. Follow the guide or advice above to locate the defective one. Make a run to Audi or VW an pick up a new one, or order some online. Simple fix.
    Established Member Two Rings AIRPATEL's Avatar
    Mar 29 2008
    A4 1.8T
    DFW
    Re: Coil Packs?
    Hey i have a used set about 2000 miles on them if you are interested?? you can also call me at 817-999-3371
    thanks
    Revo Stage 1+
    Magnaflow Exhaust
    H&R Sport Springs/Spacers
    K&N Drop In Filter
    Boost Guage
    LED Tails
    18" VMRs
