Results 1 to 10 of 10
    Feb 17 2008
    nyc
    Anyone running the VAST 85mm/60lb fueling kit?
    Just wanted to get a little feedback on this setup because all I have heard about is their 83mm/42lb setup with the rs4 maf housing. Trying to decide if I want to go with ASP or Vast for my fueling kit.
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: Anyone running the VAST 85mm/60lb fueling kit?
    Vast
    Feb 17 2008
    nyc
    Definitely leaning towards Vast but I want feedback on the 85mm setup because I think it's a new file for them and I don't want to have to deal with unnecessary problems.
    Mar 14 2007
    michigan
    call over there
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    i was the "guinea" pig for workin on one of the files for the 85mm/60 lb and it was strong just took awhile to tune it...VAST has great customer service and definetly knows what their talkin about.....EPL has proven power though with the 60 lb setup
    EPL Stage 3 Aquamisted
    Feb 17 2008
    nyc
    uber - mind telling me a little bit about your hardware setup when you had the vast kit. Did you switch to EPL just because they are local?
    Dec 08 2006
    Boston, MA
    ASP 3" DP's pj k04s stock fpr siemens 60#'s 85mm maf and open element filter with a mbc and rs4 ic's which ran a 3.5 fats time
    now i have EPL's fueling kit w/ a MBC, AWE smics, same k04's and exhaust with a modified stock airbox doing 2.9 fats times
    you can see why i switched
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    i have this setup, ubermidgets old ecu, but with a new VAST file. runs pretty good. i forgot my FATS time though :(
    Feb 17 2008
    nyc
    uber- thats a pretty serious change in FATs time. I'm guessing that this isn't off the shelf EPL and that it was dyno tuned?
    Dec 08 2006
    Boston, MA
    it was based off an EPL tune that was tweaked by a friend of mine....although i need to tweak it some more with my new IC's
