Results 1 to 17 of 17
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Car starts, then shuts off
    Just started happening, and doesnt happen always. I will start my car and it will die imediatly, sometimes it takes like 5 times to start it before it acually starts and runs. Does anyone know what the problem could be?? BTW its a 03 1.8 t
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Registered Member Three Rings Amze's Avatar
    Apr 10 2007
    2003 Audi A4 1.8TQM
    Phoenix, AZ
    Re: Car starts, then shuts off
    Does it idle normal when it finally starts?
    Check for unhooked hoses and such, have you?
    Nov 04 2007
    Minnesota
    yeah it idle normal when it finally starts
    Current:
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Go out tomorrow morning and turn it on and off 5 times at 5 sec. on intervals, but don't start it until the last time. If it starts and runs fine, the fuel check valve in the fuel pump has failed. Call your local dealer and have them run the VIN for recalls, the 03 had a fuel pump recall.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 04 2007
    Minnesota
    Quote Originally Posted by dirtybrd View Post
    I will give that a try thanks
    Current:
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    I take it there are no lights flashing on the dash....(ie the engine immobilizer one..with the key/car pic)?
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Established Member Two Rings sunthose80's Avatar
    Jul 25 2007
    what would that mean?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    plain and simple, it's your immobilizer. I am having mine fixed this Friday. Mine did the same thing over a year ago. Every once in a while it would die a few times then others it wouldnt. Then it would go a few days and be perfect and others it would be everytime I started the car. I then had my battery undone for a long period while I had a transmission fixed and the problem went away for several months. I then had a dead battery and the problem came back.
    Very easy to tell. Turn your key on and the little yellow car icon in the top center of the gauge cluster will come on with all the other lights when you first turn on the key, then it will go out then start to flash. If it starts flashing then the car is gonna die because the key didn't get read properly. So next time you start the car pay attention to that icon and if the car dies watch for it to be flashing. I am almost positive this is your problem. There is a "key reader" or "reader coil" that is part of the ignition where you put your key in. This piece has gone bad.
    A dealer quoted me over a year ago $350 for parts and labor when the problem first started on my car. I also have an 03. Like I said im taking it in this Friday so I will let you know what the cost was and the outcome.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Mar 18 2007
    B7 2.0T Avant / 2001 Silverado Z71
    Encinitas, CA
    I had this same problem, for about 9 months. The car would start and die with the immobilizer light flashing. I finally figured out that if you have a bunch of keys or weight hanging on your remote while it is in the ignition, it puts stress on the key reader and causes the malfunction. If I take my remote off of my keychain the ca has started first time every time. I am going on a month and a half without the problem. I almost dropped $350 on a new lock cylinder with key reader coil. Might be worth a shot before you drop the money.
    L8
    b
    Active Member Four Rings Kemiksiz's Avatar
    Feb 21 2006
    BMW F80 Conversion- Merc A Klasse
    Turkey
    Quote Originally Posted by 218army View Post
    L8
    b
    Hey,
    I have heard this story from one of he mechanic guys, i did not gave a f$ck. I guess I should have, coz I got the same problem these days.. I'll try the 2 option on this page..
    Thanx for the infos, I hope we all get rid of that issue without spendin any $$$
    Instagram: @m3_rhino
    Current
    B9 A4 Avant => RS4 Avant
    Done Projects:
    F30 => F80 Full Conv
    A3 => RS3 Full Conv
    Buick Tourer => Full OPC
    Apr 24 2005
    E55 AMG, CTS-V
    L8
    b
    I have ZERO keys connected to my car key/remote and never have had any. I think you just had a crazy coincidence. Like I said mine all the sudden started working for several months perfectly as well then reared its head like a year down the road.
    ~David~
    CTS-V 9.6@148
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    I had the same problem. It was the key reader coil. It's not cheap, so hopefully you have a warranty. They change it and then they charge to reprogram all of your keys.
    Nov 04 2007
    Minnesota
    i will see if that imobilizer thing is flashing, i have 2 keys i will try.
    Current:
    Mar 07 2004
    Charleston, W.V.
    If I remember correctly the immobilizer light didn't flash. The car just shut off and I had to keep trying to start it until it would stay on.
    Jan 13 2007
    Greensboro
    Mine used to have the immobilizer problem, and then it disappeared. It usually only happened with one key for me so it wasn't the reader in the car. So you could try another key to just make sure. Also I read in the manual that if you have other remote keys on the same key ring it can interfere with the audi key detection. I don't know if that was a factor for mine or not it would do it pretty consistently and now I haven't seen it for about 8 months!
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    My immobilizer broke for a weekend last fall. I ended up removing a fuse, and then plugging it back in. Dash/gauge cluster made a clicking sound. Fixed the problem and hasn't happened since...
    http://www.audizine.com/forum/showth...mobilizer+fuse
    good luck!
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Sep 05 2010
    central nj
    does it say "safe" under your trip mile counter?
    I'm having this same problem. The car will sometimes start fine, and then randomly take a few tries. It'll start and then immediately shut off. Takes a couple tries, and no flashing immobilizer light. Now on top of it all i see that the car reads "safe" in the trip screen under the tach. If i disconnect the battery for a minute it goes away, but once i try to start the car a second time the "safe" comes right back. PLEASE HELPPP!
