Results 1 to 11 of 11
    Registered User Three Rings
    Oct 08 2005
    New Jersey
    97 a4 k04 questions. fueling, etc.
    Hey im into the s4s and really dont know to much about tuning the b5 1.8s. Im about to do some work to my brothers 1997 1.8 manual quattro. I need some advice. I want to do the pc16 kit. Right now he currently has a k04, test pipe, cold air intake, giac software, fpr, and borla exhaust. What is the best upgrade for this car? pc16? what injectors does it use? Im looking for the cheapest way to do fueling. would i want to use a stock airbox or this setup is ok?
    let me know
    thanks
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Re: 97 a4 k04 questions. fueling, etc.
    pc16 uses 225TT injectors (380cc) and MAF (3")...youll probably want a new TIP as well.
    check the GIAC site for the specifics.
    Oct 08 2005
    New Jersey
    tip?
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    pc 16 uses 310cc injectors on an aeb setup. great file. throw in a n75 h valve for even more fun. bosch 310 red tops will be the cheapest fueling. will need a adjustable fpr to dial down to 2.7 ish bar.
    May 07 2007
    ah thats right about the injectors on the AEB.
    ps-that n75 is a great upgrade on even a stock k03
    Oct 08 2005
    New Jersey
    is it worth getting the kit from awe? Or homebrew? Which injectors does awe use in there kit, what co?? Not tt correct? And what mafs?
    Jan 06 2005
    san diego
    looks like the car to be setup already has giac, so 200 will be the upgrade to go k04. homebrew will be cheaper. probably has bosch redtops in their kit. you can go with those, usrt injectors, rc engineering. tt injectors won't fit aeb heads. stock maf is fine.
    May 07 2007
    no 3" MAF with PC-16?
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    ^^ stock maf used for pc16, you also will need a fmic to keep iat's down
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Oct 08 2005
    New Jersey
    So does anyone know exactly what injectors this kit uses so i can do the homebrew??
    May 07 2007
    Quote Originally Posted by 20vpower View Post
    Boost Factory SMIC FTW!
    I initially thought 380cc injectors...but 310's of any brand should do...look for a used set.
