Results 1 to 13 of 13
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    Help running wires through firewall ??
    I 'm installing a EBC and need to run a few wires for the solenoid I have the glovebox out and the raintray removed. I've removed 2 rubber plugs next to the battery but they seem to be a dead end. From the inside of the car I don't see any holes. What's the best way to get these through the firewall?
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Help running wires through firewall ??
    I only know of the ECU box
    or you could take off ur front left wheel and go through the wheel well..if u want to know about that then you could go look at winston's guide on how to install the podi boost gauge
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    With the Profec B there's not enough wire to run from the turbo location to the ECU and then back to the cupholder, I hate to extend it. There has to be an easier way!!!!!!
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    There should be a grommet the has about 6 plugs in it. Read winstons write up for the boost gauge install
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Over the battery there are 2 bolts. Drill a hole just to the left of them and limit the bit depth with some tape, poke thru the foam with a srcewdriver, then pull the glove box and you'll see it poking thru. Also, remember the install a grommet so your wires don't chafe.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings dummptyhummpty's Avatar
    Sep 17 2004
    Los Angeles, California
    There are two grommets by the brake booster on the driver's side. They are black and I think one is above the other. I've used the lower one and it drops in above over the peddles.
    If you need to contact me, send a PM.
    1965 Corvette Stingray
    2003 Audi A4 1.8tq (RIP: 2/10/04)
    2004.5 Audi A4 3.0q (Sold: 8/15/09)
    2003.5 BMW M3
    2013 Ford Edge Sport AWD
    A4 Stereo Information Thread
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    The 2 bolts above the battery? If I drill to the left of those I'm like 1in from the gromets I've removed and tried fishing a metal coat hanger through. I feel foam but on the inside above the glovebox there's this huge rubber boot looking thing it looks like it runs to the air/vent system, I'd hate to punch a hole in that, Does it matter???? I'd run the wires over to the ecu and then back to the cupholder location but the wires are not long enough. what a pain in the a$$!!!
    Jan 16 2007
    Wetzlar
    you can run cables/wires through ECU box.
    I would not run any wires Winton's way.
    Mar 21 2006
    Lakeland, FL.
    I actually ran my wires thru those bolt holes.
    I'm back bitches!
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    Are you talking about the 2 allen head bolts that hold some type of bracket down direclty behind the battery? So you removed one of those bolts and ran the wires through there?
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Quote Originally Posted by matt7127 View Post
    It's not a dead end...That is a ruber insulation use a pocker to make a hole in it and pass your wires through it...I am just doing the same thing now except I installed my turbosmart in my arm rest...You wires will be on top of the blower assembly and when you make the hole you will hit it so poke from down up with it..Once you pass the wires inside there is enough room to push the behind the blower and from there go to the console
    BetaAlphaTau member #19
    Mar 21 2006
    Lakeland, FL.
    I took that bracket off and used those holes.
    I'm back bitches!
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    Thanks!!! I'll give it a try tongiht.
