Results 1 to 14 of 14
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    APR stage kit/GT28R/oil lines
    I have a gt28r that will be fitted back to the engine temporarily until i can supply the funds for the gt3071 kit. the oil lines are somewhat crimped and the rubber hose inside looks creased. I am afraid that this will restrict the oil flow to the turbo and could blow up and result send metal into my brand new engine. Sooo.. APR sells these oil lines for $300 which is insane.
    Does anyone know of any other place to go get these much cheaper? I understand these are custom or specific sizes but 300$ i think is crazy for two oil lines.
    thanks
    josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: APR stage kit/GT28R/oil lines
    I've heard its cheaper to piece together your own lines by buying the braided line and fittings and having them assembles. It shouldn't be more than $100.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    any idea where to go to get the lines and fittings? I am kind of at a loss with these lines.
    Thanks
    josh
    -josh
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    oohhh, brother, we are in the same boat, so i would like to know as well.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    haha aren't engine builds/turob upgrades FUN?! Damn, I am going to be broke! LOL
    I was just told my local Oreilly's auto parts store makes custom hydraulic hoses, so they MIGHT be able to do oil lines also if they have the braided lines for high heat.
    -josh
    -josh
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    go to sumittracing.com
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Senior Member Two Rings Erock's Avatar
    Widebody S4 Avant
    I am also in the same boat, what fittings are need for the oil return line
    98 pearl white BT A4- gone but never forgotten :(
    01 widebody S4 wagon porsche speed yellow Tial 605's and all that goes with it :)
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    you probably need to keep the old lines around so when you get replacements you can show them what you need or measure them for that matter. I am going to try O'reilly's today, I'll let everyone know how I made out. I have to call APR today anyways so i will see what they can do for a "group buy"
    I realized i only need the shorter thicker return line, not the longer skinner feed line. Either way its going to be $$$
    -josh
    -josh
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    yea thats a big line and it has flanges crimped on both ends... not you typical AN fittings, but flanges...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Source it out through ATP's website.
    try this:
    Oil return gasket:
    http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
    Oil return flange:
    Custom oil return line #10AN :
    That should get you to your block. You'll then have to get an adapter to make the line fit on your block.
    Last edited by dougyfresh; 04-28-2008 at 11:35 AM. Reason: added web links to ATP's parts
    -Doug
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    apr will only sell them as a kit, no way to piece it out.....
    -josh
    -josh
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    o'reilly's is a no go.
    -josh
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    But you need two flanges/fittings right?
    One on the turbo and the other on the pan?
    IG:@steadysupreme
    Pics&Detail
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i already have those fittings, i just need the hose. the hose was a little creased from me carrying it around for a few months. Don't want to risk the return line not allowing the oil back out of the turbo and causing issues. just playing it safe at this point.
    -josh
    -josh
