Results 1 to 11 of 11
    Senior Member Three Rings AudiA4turrrbo's Avatar
    Mar 26 2007
    2002 Audi A4 1.8t 5spd
    More overheating issues...
    So a few weeks back I posted about a fluctuating temp gauge, well finally a few days ago the car just straight up overheated, my warning light on the head up came on, and the gauge was rapidly rising. So I ended up replacing the thermostat that day, and that seemed to fix it. However, I noticed while driving today that the temp gauge will begin to rise at an idle, and as soon as I start moving again it goes up. I then popped the hood while the car was idling, it began to overheat, and the fans did not kick in. So this brings me to my question, how are the fans controlled on these cars, are they a viscous set-up, electric, or are they controlled by that temp sensor?? Basically what do I need to do to get my fans to work?
    Thanks
    RIP B6 A4
    -2001 TT225 Quattro 6spd-
    http://www.metrodubs.com
    Registered Member Two Rings myownstylett's Avatar
    Apr 14 2008
    02 Audi TT 225- 06 Explorer
    Oak Harbor,WA
    Re: More overheating issues...
    Just a guess. Sensor for the fans or temp sensor.
    MY SECOND WIFE :D CLICK AND SEE HER
    URL: http://www.carsponsors.com/profile.php?id=172457
    Mar 26 2007
    Quote Originally Posted by myownstylett View Post
    is that whole green vs. black sensor that I keep hearing about?
    RIP B6 A4
    Apr 14 2008
    Oak Harbor,WA
    Yes it is
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    is your radiator fan busted or the connector is shot?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Mar 26 2007
    Good news: I just got done installing a new green temp sensor, and I also re-bled the system and now everything is back to normal!
    RIP B6 A4
    May 03 2007
    german
    heaven/hell
    that's good man! good to hear
    Mar 26 2007
    this is unbelievable, so now it idles, and 90% of the time drives fine with the temp gauge in the middle, but after driving for long periods of time the gauge will still move up one notch, then back down. I can't fathom why this is, my A4's temp gauge never moved. Now its more of a bother to my sanity then anything else, i mean the car had an entire new engine dropped in less than 20k miles ago, and if the waterpump was going bad I think I would have more frequent, and drastic temp problems.
    RIP B6 A4
    Apr 14 2008
    Oak Harbor,WA
    It could be a Bad thermastat. When you intalled the new one did you make sure it was in the correct position? Also when you put the new temp sensor did you install it the same way it came out?
    Jun 14 2005
    Anaheim, CA
    Do audi's have fanswitch's? and no i dont mean a toggle switch. Could be a fanswitch going bad.
    Brandon @ VMR Wheels
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Check the fan control module. Put the AC in auto, at lowest setting. Open hood and verify fans run.
    Have you replaced the WP? Should've been done w/ the TB (and metal, not a plastic impeller).
    After a hard run, my modded 180 (MTM, 220+HP) runs up a bit. After a short idle, it settles out. I Live in Atlanta, and the heat is murder.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
