Results 1 to 10 of 10
    Active Member One Ring ISLANDSTYLE's Avatar
    Feb 20 2008
    '01 B5 S4
    SOCAL
    Display Center Symbols?
    Hello, does anyone know a link to the message display symbols? I'm the third owner of an '01 S4, and I've been searching the FAQ's and archives for over an hour now.
    Thanks for the help.
    Oct 25 2007
    Seattle wa
    Re: Display Center Symbols?
    I'd check your owners manual, what symbol are you seeing?
    2000 Nogaro S4 sedan
    -AWE Downpipes
    -AWE Twin2
    -GIAC-X
    -Stasis Street Sport
    Feb 20 2008
    '01 B5 S4
    SOCAL
    Sorry, thought I put it in there. The car didnt come with the manual. If I go over 80 mph, the MPH symbol with the #1 on the upper left. Also, I washed my car, and now I got no display. Only when you go over 80. When I start my car, the display shows OK, then shows nothing.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    If you see a Palm tree or a volcano it means you need windshield washer fluid
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    I had the same thing, i looked in the manual and it says exactly what it is.
    Basically if you click in the left knob think on the gauge cluster it sets a speed notification at whatever speed your traveling. Then when you exceed that speed it beeps at you and shows you the MPH in the center display. i guess it can help to not speed??? To turn it off i think you click in the left knob thing and hold it for a couple seconds and it should turn off
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Feb 20 2008
    '01 B5 S4
    SOCAL
    Thanks, I'll try that out. Is the rest if the display linked to that? In other words, if I turn that off, will my display come back on?
    Feb 20 2008
    '01 B5 S4
    SOCAL
    Thanks, for all the input. I found the "Display Reset Button" on the A6 forum.
    Registered Member Two Rings BillKlineVT's Avatar
    Nov 04 2007
    2001 Audi S4
    NoVA
    try tapping the button facing the floor on the right stalk of the steering wheel controls... it's the reset button but if you tap it it turns the screen on and off - that took me like 2 weeks to figure out when I first got my car... mine didnt come with the owners manual either, heh
    Bill K.
    2001 Silver S4 - AWE Stage 3
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    If you see a vagina, that means your brake pads need replacing
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    Quote Originally Posted by S4-ORCE View Post
    hahaha
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
