Results 1 to 12 of 12
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    s4 tranny in a4?
    There is a s4 tranny for sale locally and its only $1000 obo with 51k on it. Will it bolt up to my 99 a4 1.8tqm? And will it be worth my time and $$$? Thanks!
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: s4 tranny in a4?
    Been asked mannnnny time before, and usually the answer is no it wont be worth your time and no it wont be worth your money. It not a direct fit so it will take allot of stuff. search more.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    97 A4 2.0TQM
    Rochester, NY
    you would need the rear end and driveshaft as well, i think you need to change the front axles too. and you'll need to change your shifter assembly.
    Aug 16 2007
    Buffalo NY
    meh ok n/m thank you!
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by pac1085 View Post
    Why would you have to change your driveshafts?
    97 A4 2.0TQM
    Rochester, NY
    Quote Originally Posted by Issam@034 View Post
    I have not done the swap myself so correct me if I'm wrong but I did research it quite a bit before I decided on the 2.8 5 spd, I spoke with some people who performed the swap and they told me that since the 6spd trans is longer, the 6spd propshaft is shorter, and that you'd need to swap out the axles/hubs/etc from an S4 into the A4. I do remember hearing something about being able to change the output flanges to accommodate the A4 axles/etc.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    You need the box,mounts,rear diff, rear shaft and gear linkage. Then it would bolt in as far as i am aware.
    I only needed to change driveshafts on my 6 speed conversion as i used a diesel box, i am sure S4's and A4's share 108mm inner cv's if not output flanges from an 016 box from a 4000 are known to fit the 01e box and then in turn fit the driveshafts.
    I couldnt find any used so ended up swapping the flanges and hub carriers to a v6 so i could use its shafts as i needed 130mm inner joints to bolt to my 'box
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    97 A4 2.0TQM
    Rochester, NY
    Jan 20 2005
    99 AJL TQS
    UK
    After all of my searches, i never found that, so attacked mine blind, I can find the write up i did on a UK forum if it helps
    Edit here you go http://audi-sport.net/vb/showthread.php?t=53158
    -Mark -
    Aug 16 2007
    Buffalo NY
    why is the 2.8 tranny better? Better gearing for turbo or just stronger?
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    Quote Originally Posted by slopoke View Post
    direct bolt in, longer gears than the 1.8t
    also, i have a question regarding this. some b6 1.8t came in 6 speed, can that trans be directly bolted into a b5 1.8t?
    Jan 20 2005
    99 AJL TQS
    UK
    Quote Originally Posted by ////D View Post
    I believe you need to swap out the gear linkage and driveshafts, as they have an odd flower shaped inner joint
    -Mark -
