Results 1 to 38 of 38
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Anywhere I can buy a coilpack on a sunday?
    I used my spare last night and have to go out today. Does anyone know a place?
    Apr 08 2008
    Toronto, Canada
    Re: Anywhere I can buy a coilpack on a sunday?
    Quote Originally Posted by audipotential View Post
    I have 4 extra ones that I'm taking out today. You can pick them up if you like.
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by lorvar View Post
    I dont need used coilpacks.
    Apr 08 2008
    Toronto, Canada
    I thought in a bind, a used one is better than none until tomorrow.
    Sep 24 2007
    Woodbridge, Ontario
    My used ones were newer than yours and mine blew under boost.
    Apr 08 2008
    Toronto, Canada
    If you have used ones in hand then you'll be ok until tomorrow. If you want one or two of my new ones you have to come and get it and buy me another tomorrow.
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    another coilpack blew??
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Senior Member Two Rings BangHatch's Avatar
    Feb 29 2008
    ToronCouver
    Was it an R coilpack that blew?
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    you and your coilpacks lol
    4 years and none hahaha
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by Siggiepop View Post
    lol now that you said that your going to have one coilpack for each year of ownage blow
    Meet Shanice...
    For Sale:
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    quick question .. other than vag com, how do u tell if a coilpack is really blown? i remember something about pulling a coilpack out while the engine is running???
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    does anyone have an older style coil pack they arnt using that can go into a b5 s4?
    01.5 A4 1.8t sport
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by GtiRSmiley View Post
    i'll tell you how, because i literally JUST finished reading a writeup on this lol
    http://forums.audiworld.com/a4gen2/msgs/1003672.phtml
    Meet Shanice...
    For Sale:
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Quote Originally Posted by mattman View Post
    Ty .. seems all of mine are fine ! Hopefully Bryan will be able to why im running lean, misfiring, and only hitting 14 psi tomorrow
    Oct 23 2007
    Ontario, Canada
    damn that sucks. let us know how that turns out...MAF maybe??
    Meet Shanice...
    For Sale:
    Sep 24 2007
    Woodbridge, Ontario
    The last of the original coils blew when I changed to copper sparks.
    Oct 23 2007
    Ontario, Canada
    did you replace them with Hitachi R's or E's? or neither?
    Meet Shanice...
    For Sale:
    Sep 24 2007
    Woodbridge, Ontario
    I didnt check. I picked it up as a spare like when I first got the car.
    BTW, I looked at my gap on the OEM platinums that I put in about 10000K ago,
    The gap was around 0.24-0.26
    Sep 24 2007
    Woodbridge, Ontario
    Wake up tommorow, youll have 2 coil packs blown. Courtesy of karma lol
    No but seriously I knew it was only a matter of time.
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    lol i guess maybe cause i'm still stock program.
    Sep 24 2007
    Woodbridge, Ontario
    Yup
    May 29 2009
    Richmond
    Hey, sorry to revive an old thread but did a search and couldn't really find what I'm lookin' for... hope someone can help...
    New to the forums (and the Audi world). :) Driving an '03 1.8TQ Avant and had hesitation problems last Friday on way home from work (couldn't go faster than 70kph on the 91! then couldn't go much more than 50kph on way to dealer the next day). I was having a coolant leak (clamp) fixed under extended warranty on Saturday, so I had them check out the hesitation and they called back saying it was coilpacks 2 and 4... they haven't given me a quote but how much should I expect to pay for these locally? I read somewhere I should just get some from the VW dealer and put them in myself? My car's at the Richmond dealer, if that makes a diff... should they be under the extended MSP warranty, or no?
    Thanks guys!
    Fred
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    In the CPO guide, it does read that ignition coils (which are really the coil packs) are covered:
    Engine – block, pistons, connecting rods, crankshaft, oil pump, flywheel (non-clutch related failure), camshaft, timing chain/timing belts (if maintenance interval is followed), cylinder heads and their mechanical components, ECM and associated wiring
    Electrical – speedometer and sensors, odometer, tachometer, temperature gauges, horns, windshield wiper motor and associated sensor, windshield washer reservoir, fluid level sensor, headlight washer pump and associated components, headlight switch, brake light switch, turn signal switch, emergency flasher switch, door switches, back up light switch, fog light switch, alarm system components, wiring harnesses and connectors (non-modified by aftermarket installations), cruise control components, starter, alternator, ignition coils, ignition locks and electrical components, knock sensors, voltage regulators, distributor assemblies, infrared entry receiver (not for battery replacement), power door actuators and associated switches, sunroof motor, sunroof switches and relays, convertible top hydraulic motor and associated wiring, window regulator assemblies and motors, power window switches and associated wiring, side view mirror motors and associated wiring, sun shade motor, air bag sensors and warning lights and associated components, air bags, seat motors and heating elements and their relays
    Mike
    Established Member Two Rings 1_8T_Dub_PimP's Avatar
    Aug 27 2007
    99 1.8T Passat
    I don't know if this will help you out but this is where I ordered mine from
    http://www.autopartsway.ca/
    it's in Canada so free shipping and the price is ALOT cheaper than I was quoted from the dealership for mine.
    99 1.8T B5 Passat~ Audi S5 style one peice headlights~Forge 007 DV~K04 Turbo~2 point upper front strut brace~KW V2 Coilovers~Thor Aluminum skidplate~ATE Powerslot rotors~HyperShift Short Shifter~Audi RS4 19x8.5 w/ General Exclaim~ Jonboy tinted Tails T3ch Blog http://t3kd.com/
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    If you're in Toronto and can drive the vehicle, Neil (clconversion) is the obvious choice.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    i thought u sold ur car fran? what happened to the altima?
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Jul 10 2007
    trunk
    Quote Originally Posted by 02B6 View Post
    lol
    audipotential - 04-27-2008 09:35 AM
    Stage 0 minus - .5
    May 29 2009
    Richmond
    Quote Originally Posted by 1_8T_Dub_PimP View Post
    Hey, thanks for the quick replies and tips! Are these something I can/should replace myself? If it's as easy as sparkplugs and wires, then I'm capable if it's what others do...
    Are these the ones I should be ordering for my car? Are they genuine parts and the latest revision?
    http://www.autopartsway.ca/autoparts...D=2003~Audi~A4 Quattro 1.8 L4~240858
    Fred
    Aug 27 2007
    99 1.8T Passat
    OK I just ordered two new coilpacks on Monday I received them today so here's the down low. I remember a site I ordered from about two years ago and the price was wayyyyyyyy less than the dealer, the coilpacks were Beru so I was really happy. The ones I got today are prenco and they have no markings on the top of the coilpack like the OEM or the Beru which has the brand and part number etc. These do come with a waranty off the site so although I'm a little aprehensive I'm going to try them out. I have searched and I can't find the site I got the others made by Beru maybe they just changed suppliers and now they get Prenco I don't know but that's what came up on all the sites I have saved. They will arrive fast because the warehouse is on Bathurst in Toronto but just thought I would put up that info I know some people will not want it because they will be scared of the qaulity. I'm going to give it a try and see I have my spares to fall back on anyway.
    Nov 05 2007
    Toronto, Canada
    i paid 48bucks at the dealer. How much cheaper can they get?
    Jul 10 2007
    trunk
    ~$40 range each I think, I'll check my receipt when I get home as I decided to buy 4 new ones a few months back (I had been using used coil packs since I got the car.)
    Stage 0 minus - .5
    Active Member Two Rings MaxA4's Avatar
    May 23 2009
    Kitchener
    I have had to replace 4 of 6 so far in the last year :-)
    Markham, ON
    Eight years of driving Audi's and not a single coilpack failure (knock on wood).
    Mike
    Senior Member Two Rings McLaren's Avatar
    May 30 2007
    '04 Audi A4 1.8TQM
    VW dealer has them too, and could be cheaper than audi dealer
    May 29 2009
    Richmond
    Quote Originally Posted by Pr0n View Post
    $40-50 range is pretty good...esp for OEM ones... still trying to get in touch with dealer (telephone tag).
    I have about 18months of extended MSP warranty left... I'm thinking that if I replace the coilpacks myself and "something" goes wrong with the ignition or related system later on, they'll try and blame me and void the warranty, right?
    Fred
    Aug 27 2007
    99 1.8T Passat
    OK well for me the coilpack is 110.12/each +Tax from the dealership so the $48 I pay is less than half price. Damn I should have gotten an Audi
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Quote Originally Posted by TSi SPY 007 View Post
    Fred
    how would they know who replaced it?
    also, how could you possibly fk this up? I'm probably the least DIY car guy on Audizine, but I wouldn't think twice about doing coilpacks. It's like a frigging lightbulb.
    May 29 2009
    Richmond
    If there's no record of it being done at the dealer, then they can basically say you or some joe-blow mechanic did it and try and defer the warranty work... I'm just a skeptic with these things.
    Latest news: they're covering the 2 coilpacks under the MSP warranty and I only have to pay for parts if I want the other 2 replaced at the same time, so it'd cost $95 Cdn for BOTH the coilpacks (like $47.50 each) and I confirmed that they're genuine Audi parts. If I want them to do the sparkplugs at same time, then the whole deal (with the 2 coilpacks) is $243, which I find quite insane, so I'm passing on that "deal". I can't believe they charge that much for like $50Cdn in parts for the plugs and 15-20 minutes of work...
    Thanks for all the help guys.
    Fred
