Results 1 to 4 of 4
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Factory Nav RNS-C
    I believe thats the code. The shitty one that pops up on the dash and has the controls on the center console. I just bought another 4.2 that has this Nav. It doesn't have any disc. Hell it doesn't even turn on or anything when I hit the buttons. Can I just remove everything? Is the antenna through the trunk? I know sometimes they use a magnetic connection through the metal with sticky tape holding on the antenna. I'm really hoping thats what it is, I much want that pimple off my car.
    If I can't easily remove all this crap, any ideas whats wrong with it? I have searched but it just talks about the better nav's.
    If anyone with a Casa white A6 wants this, hit me up.
    - Jeff
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: Factory Nav RNS-C
    It can be done but it's a major PIA. Look at last section of this thread:
    http://forums.audiworld.com/a6/msgs/782283.phtml
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Feb 12 2007
    2001 Audi A6 4.2 (sold), 2010 Q5 3.2 (sold), 2008 Lexus IS250 AWD, 2011 Lexus RX350 AWD
    Unknown, AK
    RNS-C is perhaps one of the best GPS systems out there (minus the GUI interface). If you're lucky enough to have all the C-NAVI CD's for all states, it's pretty accurate and evidences hardly any lag (i.e. missed exits because of syncing delays). Downside is obviously a painful interactive experience because there's no big navigation lcd to look at with all the pretty colors and every choice requires scrolling through the alphabet to spell out a destination. Also, they don't make updated CD's for this system anymore (I believe that least update was 2002? before they switched to RNS-D, then RNS-E, and so on). So those can be a PITA to find for the car and $$$$$$ to say the least for outdated maps. But for general location searches, it's great.
    As for working parts, check your trunk for the Navigation disc drive. It's mounted with the cd changer if you have it. If you can find a C-Navi CD for your state, pop it into the Navigation Drive and start the car.
    To start navigation, click on the NAV button on the center console. The LCD readout above your steering wheel should evidence that you've chosen to begin navigation, and then simply rotate the navigation knobs to make your choices. Pushing down on the knobs selects the option that is pointed to by the arrows on the LCD.
    It's a tedious process, but it works. And good.
    If nothing happens when you do the above, then perhaps your navi system has been disconnected or (sigh) something's busted.
    That GPS "nipple" on the rear trunk actually gets quite a few looks and both good/bad comments. Some people have even said "cool" when they see the engraved "GPS" on the dial. It's different, uncommon, and subjective (not everyone likes it, but to each his own right?).
    It was the most accurate car navigation system for it's time (IMO). This is before all the newfangled color widescreen super-duper navigation systems (dvd-based, mp3 capable, etc...) came out.
    If you don't like the "nipple", that's a difficult situation, because after all these years, the paint underneath will likely be a different shade than the rest of the car. Also, I'd have to double check, but I think the nipple is not just "glued" to the trunk, but perhaps screwed or bolted down so that it doesn't pop off while driving.
    I have the 2001 A6 4.2Q with Navi...and for me, it's great.
    Btw, I did go out and buy a Garmin Nuvi 660 for the nice color LCD widescreen, text to speech and updated maps.
    A lot cheaper than getting the RNS-D/E mod for $1500 or more.
    Although RNS-E does look pretty. Won't deny that.
    But on a car that already cost $60K new back in 2000, I just couldn't justify spending any more money on her today other than functional mods and maintenance (brakes, suspension, etc.).
    I wouldn't think that the time and effort for you to remove all this would please you in the end, given all the cleanup necessary and expense involved. But I guess if it really bugs you, then I wish you the best in resolving this issue.
    Cheers.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Got it to work! Now I just need some Nav disc. Working on that since they are impossible to find. Anybody have a torrent sit I could download them from?
    Village Idiot!!!
    (\__/)
    (")_(")
