Results 1 to 13 of 13
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    Question Advice: apr stage 1 chip upgrade
    Yesterday I got the stage 1 93 octane upgrade and it is sweet for a 1.8t, better than a 3.0 in my opinion. Anyways, if I run the RPMs up to around 3000-4000 and then hit the clutch in, it will dwindle down past 900 RPM and then cut out. Also, if I got some TT225 injectors are they a direct replacement? and will the flash a big injector file for APR stage 1? thanks
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Advice: apr stage 1 chip upgrade
    What do you mean about the rpm ranges?
    When you get the TT Injectors, you install them and get the Stage 1 reflash to 1+
    Jan 13 2008
    Charlotte, NC
    Unhappy Re: Advice: apr stage 1 chip upgrade
    by that I mean: let's say im in 3rd revving up to get speed, if the RPMs are around 3000-4000 and I push the clutch in and put it in nuetral, that motor idles out while im rolling. It does not do that if I put it back into a gear
    GReddy Turbo Timer
    Forge TIP (RED)
    Sep 24 2007
    Woodbridge, Ontario
    You mean the car stalls?
    Jan 13 2008
    Charlotte, NC
    yeap
    GReddy Turbo Timer
    Forge TIP (RED)
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by treemolecule View Post
    yeap
    Is this your first standard car?
    Someone else would know better than me on this topic because ive never let the rpm drop to that level before shifting.
    Jan 13 2008
    Charlotte, NC
    no I've driven manuals my entire life, what it should be doing ( I think ) is idling out at 900 instead of dropping past
    GReddy Turbo Timer
    Forge TIP (RED)
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I dont really understand... You mean if you keep the gas pedal IN and while doing that you go to N, your RPMS go down, right??? I dunno then.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    I think he's trying to say that his car stalls when he pushes the clutch in for a little while without putting it back in gear.
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    800-900rpm is normal. Anything below that you have a problem.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Registered Member Three Rings
    Jun 11 2007
    Quote Originally Posted by AudiAdi View Post
    thats what i got from his post
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by jcll2002 View Post
    Exactly
    Apr 08 2008
    Toronto, Canada
    B6 A4 1.8t (Q) 6spd
    -AFE Intake (Injection Molded plastic rocks!)
    -3.75x6" K&N Cone
    -Turbosmart MBC
    -GReddy Turbo Timer
    -Faze Boost Gauge
    -034 Denso Line Motor Mounts
    -APR Stage 1 Chip Upgr.
    You have a chip and a MBC??!! Do you have a blow off Valve?
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
