Results 1 to 18 of 18
    Mar 27 2008
    06 A4 2.0T Q MT, Jeep GC
    PA
    Stock intercooler mods
    i was looking at the stock intercoolers and noticing that the ducting to them is pretty good but the airflow doesnt really exist because of the plastic behind them to the wheel well, sooo i was just wondering if anyone has really ever cut louvers or slots or just cut big holes in the plastic behind the intercoolers and in front of the front tires??
    The FMIC is awwwfully expensive and the stock ducting is actually pretty good, routing fresh undisturbed air to the intercoolers, just that the air has no where to flow to...
    Anyone messed around with modding them at all???
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Re: Stock intercooler mods
    If it makes sense then try it. I havent heard of anything like this but if you come up with something that works, you're method will be famous in the DIY world. Especially since it is something that keeps engine temps down people are always trying to keep it nice and cool in there. You should toy around with it and see what you get.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Quote Originally Posted by A4 KiDD 810 View Post
    that's a very old and popular mod with the 1.8t's b/c the smic sucked and had the same problem. and there was only 1, not 2. it does work, as countless people have done it before. however, it doesn't look especially appealing, so for an audi, you either better do it neatly or discretely.
    Established Member Two Rings MrRevesz's Avatar
    Oct 08 2007
    2012 Audi Q7 TDI
    Mid-Coast Maine
    Quote Originally Posted by AAAA View Post
    Pimp line, I like it
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    I'm sure it would help a bit but you wont notice anything.
    Our DSMIC's are very efficient for the K03. Take a look at the intake temps on FMIC's v.s. stock DSMIC's - they are only about 5 degrees cooler on average.
    I like the idea but I honestly don't think its worth the time.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I say try it ....
    Do a Dyno run b4 and after and see if it made any diff. Log the temps as well. sounds lke a inexpensive mod.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    It wouldn't make a noticeable difference, but I would do it on my car... I remember my TT had the vented plastic, but the A4 sure does not. I'm not sure if you can buy the oem piece that is vented but I have seen others buy shitty pieces to squish in, but if I found a good looking piece I'd totally do it and write up a DIY.
    Ignorance is bliss.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Would it make a differece on my A4 1.8tq b7? I only have one IC on the left side.
    E
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Just have someone log normal, then remove the wheel liners and log again, that will tell you everything you need to know without cutting anything up.
    -Kris
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    There are vents on B5 S4 and RS4 DSMIC's. That's why the RS4 has the shark gills on the side of the front valence. Interestingly, the B7 RS4 front valences (and copies) have the gills. HHMMMMM....
    "Obsessed" is a word that the lazy use to describe the committed.
    Jan 24 2007
    Wisconsin
    They must put the vented fenderliners on the high performance cars for a reason... Audi wouldn't do things that waste money just because they felt it might look cool
    Ignorance is bliss.
    Established Member Two Rings fD3S's Avatar
    Dec 08 2006
    3rd Gen Mazda RX-7 tt / 07 A4 2.0T 6MT
    SouthFlorida
    This may work.. maybe also coupled with a metal intercooler pipe will show a noticeable gain. I've been wanting to make a custom IC pipe to help with pressure drop. Think about it, the stock piece is rubber, dont you think that under 19-20 psi the hose would expand a little bit, loosing some psi?
    07 A4 2.0T 6MT Quattro - APR 93/100 - Stasis coilovers - Ecode TP
    93 Mazda RX-7 tt Petit ECU, Down pipe, Catback, ACT clutch, HKS bov, K&N filters; Tein lowering springs, 99 Front end
    04 Suzuki GSX-R600 Yoshimura pipe; K&N filter; Vortex Sprocket; HID conversion; Hotbodies undertail
    Senior Member Two Rings b7cruiser's Avatar
    Jan 16 2007
    B7 2.0T
    So Cal
    anyone try it yet?
    A4 2.0T Avant Q 6M
    Phantom Black Pearl with Ebony Interior
    Nav - Convenience - Titanium - Bluetooth - S-Line
    Jan 24 2007
    Wisconsin
    I stared at this metal piece that would work the last time I was at the hardware store, but didn't feel like hacking up my fender liner that day. It would be a very simple mod... maybe I'll try it next time I have a free weekend.
    Ignorance is bliss.
    Mar 27 2008
    PA
    __________________
    so that shark vent comes from behind the intercoolers?? i wonder why the little indents are in the fender liners.... does the rs4 or s4 have those little indents in the fender liners cut out at all?
    i dont know about the rubber pipe expanding.. thats some pretty rigid rubber... its probably like reinforced between layers of rubber so it doesnt expand like that... i mean its the same guage stuff that is used for the radiator right?? how much pressure does a hot cooolant system put on the hose??
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    I'm actually going to attempt the mod the OP has stated over the summer. Here's a quick/rough/crude photochop that I completed a few weeks ago based on the theory.
    Quote Originally Posted by Phrost View Post
    Yes, they do this for a good reason too!
    It's involved in helping the diversion of cold(er) air through the front bumper, and helping that air circulate around the inside of the wheel- an effective way of cooling the brakes.
    OP: you ever thought about chemical intercooling? That's definitely a possibility too- I believe there's a vendor/sponsor on this forum that has a kit out too.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    Quote Originally Posted by John1.8T View Post
    Any links to this info?
    I looked at http://www.awe-tuning.com/pages/info...cfm?content=59
    I'm still kinda noobish on understanding Dyno charts. Does your statement have any validity compared to these charts?
    p.s. I have read some other posts from AWE and remember them saying something about the stock intercoolers being pretty good. That's why they had to make it so BIG. And that's probably why there are "noticable" gains.
    Established Member Two Rings Awulf's Avatar
    Aug 24 2007
    Ft. Lauderdale
    Here is mine, cut out wheel liner and put in mesh should increase low pressure behind ICs and help the air flow through more efficiently. But sorry I have no logging, in fact I've never thought about cutting down a tree... [IMG][/IMG] Oh, and I got the brake thing done too...
    Awulf
    Blk/Blk 2007 B7A4 2.0T Sline Tit. MT6
