    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Trouble code help!!!
    Got a flashing cel with the following codes could someone please tell me what they are. Stuck on the side of the road with a shareware version of vag com.
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 UNI 518 BT
    Component and/or Version: 1.8L R4/415 G01 0003
    Software Coding: 0016501
    Work Shop Code: WSC 00210
    7 Faults Found:
    17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
    P1111 - 002 - Lower Limit Exceeded - Intermittent
    16502 - Shareware Version. To Decode all DTCs
    P0118 - 002 - Please Register/Activate - Intermittent
    17698 - Shareware Version. To Decode all DTCs
    P1290 - 002 - Please Register/Activate - Intermittent
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 001 - Please Register/Activate
    16685 - Shareware Version. To Decode all DTCs
    P0301 - 001 - Please Register/Activate - Intermittent
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 001 - Please Register/Activate
    17658 - Shareware Version. To Decode all DTCs
    P1250 - 008 - Please Register/Activate
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Trouble code help!!!
    Check B6 section I posted there.
    Dec 05 2007
    16502/P0118-Engine Coolant Temperature Sensor (G62): Signal too High
    17698/P1290-I could not find
    16684/P0300 - Random/Multiple Cylinder Misfire Detected
    16685/P0301 - Cylinder 1 Misfire Detected
    16688/P0304 - Cylinder 4 Misfire Detected
    17659/P1250 - I could not find
    Apr 16 2007
    Queens
    I picked this car up from the dealer and they pressure washed the engine bay. Im thinking they fubard the coilpacks what do u guys think?
    2003 A4 1.8TQM
    Dec 05 2007
    I am no mechanic, but that is what I was going to recommend you replace. I am sure someone with knowledge about this may chimmey in and tell you a different route to take, but this section is usually dry. You should have posted in the regular forum, even though you did post in the correct section.
