Results 1 to 17 of 17
    Veteran Member Three Rings haroulli's Avatar
    Mar 06 2007
    Audi A6 C7 - BMW X5 F15
    East Coast
    B6 OEM Tire Pressure 235/17/45 Z
    What do people run their 17's at?
    Since bought an accurate tire pressure gauge i set them at 33psi front and back. Which was very good as it got rid of a vibration from the rear which i have been suffering at, at highway speeds.
    However, I figured this was a little low so i put them up to 34psi and this caused a vibration to come back.
    I live in Charleston SC so its going to get hot pretty quick here. So i'm trying to see what i should set them at for the hot weather. I do a lot of city driving for work but i often drive to my inlaws which is 3hrs away.
    I want whats going to be best for comfort and gas milage!
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: B6 OEM Tire Pressure 235/17/45 Z
    summer 33/33 32/32
    winter 35-37/35-37
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    32 check before a long drive
    2010 A4 Avant
    Registered Member Three Rings Charlie's Avatar
    Sep 16 2006
    West Haven CT
    Its really preference. I Like mine closer to 40, I try and keep them around 38 because I have 19's with a 35 series tire. Personally with 17's and a 45 series tire I wouldnt go under 35.... But thats just me. just try and keep it between 32-42
    |Stage 2+ B5 S4|
    FOR SALE
    Jun 30 2007
    Raleigh, NC
    ^im with charlie. i keep the tires on my 19's at 40.
    if you want to go with OEM it should be printed on the sticker inside the driver's door sill.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    There is a sticker on the inside of the (passenger?) door that lists "correct" pressure for our cars. On my avant it lists 36 with 1-2 passengers and 38 for 4 passengers
    This is a pretty good starting point and can be adjusted from there depending on preference. I tend to get better tire wear at the higher rating, but my alignment was off, so it may be different now...
    Higher pressure should yield better mileage, but can wear the middle part of the tread quicker if the pressure is too high. Lower pressure can wear the edges of the tread, but will give your tire more contact with the road and in certain conditions increase grip.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Established Member Two Rings gotquattro's Avatar
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Running 35 in the front & 38 in the rear...
    Got Quattro?
    02 Silver A4 Sport (sold)
    3.0 Q / T / S
    14851's | RS4 Rear Sway | Slotted F&R w/ Hawk HPS & Stainless lines | APR Snub
    2006 MazdaSpeed6 GT #3476
    - clicky-clicky for details
    Mar 06 2007
    East Coast
    I appriciate everyones reply.
    Just to clarify i have stock 17" B6 rims with the 02 sport package, with Nexens(?) on the front and Yokohama on the backs. Both are directional and Z rated.
    On the door sills i think it says 30 front and back for 1-2 passengers. However, its a little hard to dicipher as its rated for Y tires. Plus 30 see very low to me. The tires sag. However, i'm worried that if put something like 34/35 in. The heat with cause them to be over inflated on long trips in the heat. My tires are rated 40psi max.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I run whatever my tires suggest, right now I keep them all above 40.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    I have a sport and always keep them a few psi higher than what's specified in the manual. I think 38 or so. It's actually time to adjust again them now that Spring is here.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Buncha motorcycles
    Memphis, TN
    its inside the drivers door, look on the tires and see the max setting... its up to you, we cant tell you how much air to put in your tires, it depends how you like the car to ride!
    APR Stage 2/AWE Intake
    Mar 06 2007
    East Coast
    Whats listed on the door is for Y rated tires not Z i want to know if the same is applicable.
    I'm trying to base my decision on other peoples experience. I dont expect anybody to "tell" me what to put in my tires.
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    does the load rating of the tire factor into this as well?
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    35 all around...check before long trips or every three weeks.
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Registered Member Two Rings TheBigO's Avatar
    Apr 13 2008
    '05 B6 A4 SE 1.8t CVT
    Atlanta, GA
    With some of the pot holes around Charleston I think you're running a good number.
    I know my father had issues with tire PSI getting way to high in the summer, and he's in Mt. Pleasant. He got a rotation at Geralds (I think that's what it's called) and they put the PSI high, then after a few hours on the road POP! Right front went.
    Mar 06 2007
    East Coast
    Just to update i set the fronts to 34 and left the rears to 33, I'm usually the only person in the car and the of chance my wife. We rarely have people sat in the back.
    BIGO i hear you there!
    Thats how i blew my rear right! I told the dealer to set the PSI to set the PSI for a fully loaded car as i was driving down the FL with the wife and another coupe as well as a full trunk for a wedding. On the Monday after i was driving alone to a client and my right blew.
    The heat sucks! Charleston pot holes suck!
    What does your father drive? I used to live in Mnt P but i'm now in James Island.
    Jan 12 2008
    02 A4 1.8T, 99 Passat 1.8T
    San Ramon, CA
    Quote Originally Posted by haroulli View Post
    Are you sure the 40 psi is max inflation not max for tire beading? My Yokohamas max at 50psi. I have an 02 sport and an Audi performance shop recommends psi around 40. Since the lower sport suspension have a negative camber, our tires tend to have more inner wear. Keeping the psi around 40 will also help with this. My fronts are 40 and rears are at 38.
