Results 1 to 27 of 27
    Established Member Two Rings Jaxspeeddemon's Avatar
    Oct 17 2006
    2001 Casablanca S4
    Jacksonville, Florida
    anyone know a mafless tuning for gt3071
    i have tapp tuning on my gt3071r but making a 4 inch intake on my car is a real pita, is there anyone out there know of or have a setup that does not require a MAF?
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    Re: anyone know a mafless tuning for gt3071
    yeah its a PITA but once its overwith, its a non-issue.
    Tapp tune was made for and around that MAF, so unless you can create your own files and /or tweak tapp's, then I'd say the answer is no
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    The only MAF-less files around are for 2001 and up. So you are outta luck there.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    ^^^^Yup 2001 mafless with a 3071r. Unitronic 630 file. Uses then map sensor. Runs amazing!!!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Most tuners will only do a speed density tune for the cars that came with a map sensor and a wide band 02, so this means 2001+.
    Oct 17 2006
    2001 Casablanca S4
    so it looks like standalone is my only option or make a better intake.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    i thought there where mafless tunes for all me7? uni? although i see you are 1999 do i think your SOL unless you go standalone
    ::2002 S6
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    You can do without the MAF if you have a MAP, the tuner sill tune based on pressure not airflow, same principly as most SEM's out there, go off the map sensor.
    Dec 05 2007
    I am a noob when it comes to cars, so please pardon if this seems like a simple inquiry. But I have an 01 and eventually want to go BT or BAT. Does this mean I do not need a VR6/Lightening MAF?
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    it all depends on your tune you choose, but yes you have the option of running mafless since yours can be tuned off the map sensor like killa said
    ::2002 S6
    Jul 07 2004
    socal
    Well unless you can find a tuner that would be willing to swap in a map sensor in place of the maf which is one of the things I talked to GIAC about, only problem is that the car still isn't running a wide band 02 sensor which is easier to tune since the tuner can just program the ecu to hit a set AFR target during WOT.
    Dec 05 2007
    I want to get the info now to do the setup properly when I do go BT. But for tune, I am going to go by the recommendations of other users on this forum board and get either CTapp or Unitronics. Those tunes require for MAFs? Add some don't?
    EDit: I meant to say those (CTapp and Unitronics) do not require MAFs? And some do? Seeing how mine is an 01, I will not need a MAF because they can tune the ECU to adjust the Air to Fuel ratio from the MAP sensor and Wideband 02.
    Feb 28 2007
    04 a4 USP ; ATS
    CTapp has mafless tunes for the 01 and up. I dont know about UNI. Like everyone else said its all about who you choose.
    Sep 23 2006
    Jersey
    You're such a smart guy.....
    You can even convert a Maf to MAP on the me5 dude.
    Feb 28 2007
    04 a4 USP ; ATS
    So, why not just require cars who want to run MAFless to have a wideband setup? The tune would most likely be an off the shelf, plug and play deal right? So, make it available to all who use wideband setups who have the map sensor. When Chris tapp told me he had mafless tunes for the 2001+ guys cause they had the map sensor+wideband, i was kinda annoyed, cause my car has the same thing, except im a 2000, just doesnt come stock with the wideband. Am i thinking completely wrong here?
    Jul 07 2004
    socal
    Quote Originally Posted by njm23 View Post
    Well its not just that the car has a wide band installed, it is that the car actually uses a wide band for the stock ECU which is the 2001+ cars.
    Feb 27 2005
    North Wales, PA
    dodooohhhhhhhh, i haven't spoken to chris yet.....so he doesn't have a mafless tune for a 2000? i'm so irked......who has mafless tunes for a 2000?
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Quote Originally Posted by Poopie View Post
    034 does j/k. I remember Killa was researching about converting the MAF sensor signal to a MAP sensor signal.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Feb 28 2007
    04 a4 USP ; ATS
    Ahh, i got ya, yeah that makes sense. yeah poopie, I haven't found anything for mafless on a 2000, I talked to chris for a while on the phone about it, but he made it sound like it was not happening on a 2000 or earlier.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by gotaudi View Post
    Can be done but the time and effort involved in making a conversion kit will not be worth it as only a few of us are AEB's.Most of the Audi's on here are DBW
    Feb 27 2005
    North Wales, PA
    oh well, atleast the s4 maf is smaller then the ford.
    Feb 17 2005
    Sarasota, FL
    How high does the stock MAP sensor read?
    Jul 07 2004
    socal
    Quote Originally Posted by A4ringedONE8T View Post
    ndbw = 187
    dbw(00-01) = 215
    Those are the stock #'s, the tuners can rescale them to read higher.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    ndbw = 187
    dbw(00-01) = 215
    he said MAP. not MAF
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 07 2004
    socal
    Quote Originally Posted by sean1.8t View Post
    Hahaha, didn't even notice that. Damn that P. Just dont get many people that ask what the max reading is on the stock maP sensor.
    I would post the info for that but no longer have any of the logs of block 115 that I used to have on my old computer. IIRC it is right around 2500 mbar or just under it.
    Sep 23 2006
    Jersey
    It can be done, i've been sidetracked with other stuff, but it might be as easy as getting a tuner's file and converting it.
    I've been poking around in the code for NDBW for many years - anything can be done, as long as you know what you're doing.
    The problem is how Load is calculated. Load is used for most of the maps in the software, fuel, timing, boost, etc. Load is based off of MAF and RPM. If you know what you're doing, you could change Load to be based off of just MAP.
    On top of that, the base fuel calc is based off of MAF, you'd need to replace MAF with MAP, temp, and RPM.
    The alternative is a programmable external box that has MAP, temp, baro, RPM inputs, and outputs a MAF signal the stock ECU can use.
    John Baas
    1997 Audi A4 - 2.0 T3/T4
    http://home.wideopenwest.com/~johnbaas/
    2001 BMW M5 - stock.....ish
    1991 VW Jetta - 16V ITBs w/ MSnS
