Results 1 to 36 of 36
    how to: mod 1 piece torsen diff. with pictures.
    me and my friend modded his b6's 1 piece center diff earlier this afternoon.
    the 1 piece diff in my b5 was the exact same as his. so all these steps are the same for b5 and b6.
    i figured i would let the pictures do the talking. post any questions.
    you must knock the torsen out of the housing. hit the shiny part.
    contact via email please.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: how to: mod 1 piece torsen diff. with pictures.
    Nice
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Sep 02 2005
    Montreal
    Approximately how many hours of labor?
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    care to explain?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Here are pictures of my center diff...
    ...after the gears sheared off from shimming it with washers to add pre-load (the 4:1 modification)
    Quote Originally Posted by 400HPA4 View Post
    i have already seen those pictures. i found them while i was researching the project.
    it sounded as if staggered wheels was your problem. and not the actual mod.
    http://www.socaleuro.com/forum/showt...x.html?t=13726
    took us 2hrs.
    Quote Originally Posted by vdubstreets View Post
    care to explain?
    this turns your center 2:1 diff into a 4:1 diff. *cough*stasis*cough*
    Dec 19 2007
    York, PA
    im still confused...i dont see any differences...i guess im retarded...
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by k0mpresd View Post
    Incorrect...
    If you run a tire that is 235-35-19 all the way around, the tires are not staggered.
    It has to do with adding preload which gives you incorrect gear lash...
    ...ultimately leading to premature failure.
    this mod does not add shims.
    the washers going in the diff are the exact same size as the ones they are replacing.
    i find it funny you havent posted in any of my other threads about this mod.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Did not know it was you that was selling the kit and I did not know this thread was related...
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Incorrect...
    The plot thickens
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Greg, please explain....because I am
    What kompressed says is true....if indeed you adding these washers (with the same thickness) you should not be preloading anything, therefore the lash should remain the same...............
    -Sami-
    Registered Member Two Rings Laconvail's Avatar
    Oct 28 2006
    2002 A4 1.8TQM, 2005 GSXR 600
    North Carolina
    I dont see this mod causing a failure. We even went and beat on it a bit afterwards.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    quick question...
    if ur replacing washers with ones that are the same size, how does anything change?
    i've been reading through all of the threads for this, but i can't seem to understand how it works. i understand the final product and what it's meant to do, just can't seem to grasp how it does it.
    anyone care to explain to a simple-minded guy?
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Oct 28 2006
    North Carolina
    The orange on the removed washers is an antifriction (teflon) coating. The washers that go in their place dont have that so there is more friction than there was before.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    just read all your threads, great info!
    do you know if the B6 S4 uses a 1 or 2pc diff?
    Quote Originally Posted by ngng View Post
    thanks. this is a good one as well. has some pretty good info in it. http://audizine.com/forum/showthread...hlight=shudder
    b6 s4 would be 1 piece. but i checked etka. doesnt look like its an 01e diff. so im not sure what size washers it would take.
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by Laconvail View Post
    since there's more friction, can we expect more wear and tear?
    Jun 30 2007
    Raleigh, NC
    does anyone know what it would cost to get a b7rs4 diff second hand, and if it would even be a plug-n-play option for our cars?
    i'd imagine it's much more expensive than other options out there... but i'd be interested to see how they increase the torque bias on the rs4 - THAT would the method i would be most interested in using.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    B7 RS4 Center Diff part number is 0A3 409 751 J retail is $1015
    A4 center diff part number is 01E 409 751 F and the retail is $1015
    S4 center diff part number is 0A3 409 751 B and the retail is $1015.
    Oct 28 2006
    North Carolina
    Quote Originally Posted by NyteEscape View Post
    Probably not based on where they are in the diff. I will keep driving it and Ill find out. Im not worried though.
    Oct 28 2006
    North Carolina
    Probably not. You can talk to K0mpresd. He supplied me with the parts. He is running it too. He has no problems.
    Jun 30 2007
    Raleigh, NC
    hmm... so 0A3 diffs WONT "drop" in place of a 01E? or they will?
    The Awesome™
    if anything happens to mine, i will be sure to post about it. but for now everything seems fine.
    and b6lovin, i dont think anyone here really knows the answer to that question. maybe, but i doubt it.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Ian, I was reading through a couple of your threads and I understand how everything works, but I did not find where (or if) you explained how you know the friction of your washers makes the torsen a 4:1 as apposed to a 3:1 or 5:1 or 6:1 etc...etc...
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jun 30 2007
    Raleigh, NC
    ^my guess was either trial and error with materials (seems unlikely) or because that's the way that rs4 diffs are constructed... hence i asked about that earlier.
    but it appears that nobody knows much of anything about the rs4 diff.. atleast not anyone in the b6 forum
    The Awesome™
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by actlsub9 View Post
    torsen supplies the washer tolerances and the expected outputs
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    torsen supplies all the info anyone could ever want about their products on their website. if you feel the need, go look it up and read it.
    but Ian and a few others have spent countless hours researching this stuff for you. so you don't have to.. just like STaSIS.
    only, this is a fraction of what STaSIS charges.. and they actually use quality, precision machined washers. instead of shims
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    how much is this?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    i actually called them on the phone and talked to them about the mod.
    Quote Originally Posted by GTMRS4 View Post
    how much is this?
    please see my other thread for details. this is thread is solely for information, not sales. and is done under my personal username. http://audizine.com/forum/showthread.php?t=206708
    Jun 13 2005
    Audi
    Quote Originally Posted by sean1.8t View Post
    Can you point me to where on their website it describes the relationship between the coefficient of friction of the washers to the torque bias ratio.
    Ian, if this is something that they told you directly ie: "if you use a washer with a coefficient of friction equal to X then you get a X:X TBR" then just say so. I don't need any proof or anything, not doubting you at all, I'm just curious as to how you choose what material will give you a TBR of 4:1.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    they actually said bronze is a better material to use than steel because bronze will never "weld" to steel. but said steel works fine. even the washers they recommend to use as replacements are steel.
    check #19. http://torsen.com/fsae/fsaefaq.htm
    the only thing about flip flopping the washers in the audi diff is they are both teflon coated. it appears the diff they are referring to in #19 uses 1 du4 coated and 1 bronze washer.
    bump. check sig. ;)
