Results 1 to 2 of 2
    Feb 18 2008
    03 3.0q tip, 00 BMW M road
    Delaware
    Coolant Temperature Gauge on 3.0
    I've searched and found a few threads on the sending unit being bad on the 1.8t cars.
    I have a 3.0. Some days gauge works, some days doesn't. I'm assuming sender is the problem.
    Few things
    1. is this a common item on the 3.0 too?
    2. where is it located on the motor?
    3. is it the same part number to fix?
    Thanks
    Joe
    Registered Member Two Rings Laconvail's Avatar
    Oct 28 2006
    2002 A4 1.8TQM, 2005 GSXR 600
    North Carolina
    Re: Coolant Temperature Gauge on 3.0
    ECT's go bad all the time. If you remove the intake pipe you can see it. Its down on the rear coolant pipe. You can reach back and get it. Should be a standard green sensor.
