Results 1 to 17 of 17
    Established Member Two Rings Sonny 3.0's Avatar
    Feb 26 2008
    2002 Audi A4 3.0 / 2002 Jaguar XKR 100
    Miami Beach, FL.
    Question Spark Plug Recommendation
    I was at the Audi dealer, they said to get the OEM plugs for my car as replacements. My 3.0 is generally stock, and I was wondering if any of you knew of some good plugs to use for replacements. I'm looking for something reliable with maybe some type of performance/better spark when I replace them. Should I get the OEM plugs? Should I get something else? Any word off hand for part numbers?
    2002 A4 Quattro 3.0 - Brilliant Black - 6 Speed - K&N Drop In - ECS Side Markers - DEPO Tinted Tails - Tints 30% - 18X8 BBS RXs
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Spark Plug Recommendation
    Denso Iridium IK20 is good for you
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 26 2008
    Miami Beach, FL.
    Thanks Man...
    Feb 26 2008
    Miami Beach, FL.
    Any Idea how long I can expect them to last????
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Get the NGK Iridium IX.. I used those when I changed out of my Stock ones and they sure do the job.. They last somwthing like 65k depending how you drive. Also they are said to give you a bit more power.
    Heres the specs:
    Iridium IX Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, ISO Length, Projected Tip, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .044" (1.1mm) Gap
    May 03 2007
    german
    heaven/hell
    if you are anal, change them every 10K. if not, they last at least 50K. but i would change mine every 25-30K just to keep with the maintenance.
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    NGK Iridium !!!!
    Aug 08 2007
    A4, GTI, Corrado
    Jacksonville, FL
    just ordered a set of iridium IX... can't wait to see how they do.
    Feb 26 2008
    Miami Beach, FL.
    Just ordered Denso Iridium IK20's... Ill keep you all posted on how they do. I can't wait to see the difference because I havent changed my plugs in like 30,000 and i'm definitely feeling a lag, hahaha hopefully not for long...
    Sep 23 2006
    Houston TX
    I just bought some IK20s off ebay, should be here very soon. Anyway, my car is supercharged so I'll post up on how they work on that application. I may play with the gapping a little too, and bring it down to 0.040 or 0.038"
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    will this spark also work with 1.8T??
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Feb 26 2008
    Miami Beach, FL.
    I heard that you shouldn't change the gap in iridium plugs as it will mess with how it works... The sight on Ebay says not to use a gap tool to make any changes to the plug????? I dunno tho... I'll also keep you all posted on the change with the new plugs. Also, Ill, let me know the difference with the gapping experiment...
    Senior Member Two Rings fbottone's Avatar
    Sep 27 2006
    Stratford, CT
    I think they say that because the tips are delicate and easy to break off when gapping. It shouldn't affect operation of the plug at all...
    [ :: 2007 2.0TQ6MT :: Stock!!!! :: 44000 ]
    Feb 26 2008
    Miami Beach, FL.
    Just installed my Denso IK20's... Now its like i'm driving a different car. What a difference. I'd recommend these to anyone. they are a little pricey, but IMO its def worth it. I noticed an increase in my throttle response, and power, not to mention I have much better fuel economy... A++ on the Denso's...
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Shoud i use IK24 for my 1.8t?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    This is a thread everyone should read on spark plugs. Good write-up.
    http://www.audigeeks.com/forums/index.php?topic=56.0
    I have used and tested (logged) a variety of plugs from F5DPOR, 7E's, 3 prong bosch, IK22's, oem, etc. The best I've found are the NGK BKRE8EIX. The 7EIX are good but the 8's being one temp range colder are better for my application with the power I'm running.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I've been told by two different shops now that the stock plugs are the ones to stick with, even in 500hp B5 S4's he said the stock plugs "just work better". I ran the BK7RE's for a while and honestly I don't notice a difference now that I'm back to the oem plugs. BTW copper should always be better than iridium for boosted cars as long a you don't mind changin them every 6-10k miles. The Bosch plugs in the two step colder section sound interesting, anyone know if they make those in 1-step colder?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
