Results 1 to 6 of 6
    Apr 24 2008
    Finland
    Bilstein b16 pss9
    Hi!
    Have this coilover set anyone with a4 2.0tfsi quattro?I order 20"x9.0" offset +39mm front and 20"x9.0" offset +29 rear.Tyres 235/30/20 continental3.
    I like to now it is ok front do not hit coilover.I think rear is not be risk?
    Best Regards Sam
    Jul 11 2005
    NorCal
    Re: Bilstein b16 pss9
    Quote Originally Posted by jasonbourne0409 View Post
    Hi!
    Best Regards Sam
    I think, I and anyone else who read this didn't understand anything you said...
    B7 Manual Quattro - Quartz Gray - Sport Suspension
    Neuspeed SS/Exhuast | APR Snub Mount | 12" Sub | Hoen Fog Lights | Rear Spoiler |RS4 Sway Bar | APR Intake/Chip
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    20x9" in the front will be tough to fit...
    those wheels are big... and wide. most setups stay at 8.5" in the front.
    with some negative camber you should be ok to tuck them. You will probably have to keep your suspension a bit higher than you may like though.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    ...... Que?
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    "Location: Finland"
    Give him a break
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Quote Originally Posted by ambarsaria View Post
    I bet he can speak more languages than you can Don't pretend you can't understand him. 20x9" +39 front, 20x9" +29 rear, tires 235/30/20 all around I'm assuming with Bilstein Pss9 coilovers.
    Jason, I think you can get the front to fit, but with a wheel that wide it may have to poke a little bit, which would mean you will be rubbing if you drop your coilovers too low. But I think you will definitely need a spacer so your tire/wheel won't rub your strut, and the question is how wide of a spacer will you need for the front. If you are getting everything installed at a shop, I would have them check the fitment and determine how wide of a spacer you will need, assuming they sell spacers also.
    I do not know if anyone on here can give you a confident answer since your wheels are so big though...
    Ignorance is bliss.
