Hey, this isn't for me this is for a buddy of mine and hes having some serious issues starting his car. He's checked mostly everything so far, but all the car does is crank and not start. Its getting fuel, its getting spark, just not starting. He sent me a few pics which i will upload of some disconnected plugs and his setup but here are his codes that were read
P0238 its from the torbucharge boost sensor A circuit high
P0341 is from the camshaft position sensor A
P0106 is manifold absoltue pressure/BARO sensor range/Performance
A timing belt job was done on this car, and i have concluded that it is either off by a notch or so, or it is the ECU which is tuned by Unitronic.
Sorry if the pics are crappy but thats all that we have to work with. With a GT28 install I don't think there should be wires that would be moved or taken out lol, everything is the same other than hardware basically. and there he circled in red of a location where it looks like something is missing that is suppose to be there. I haven't had the chance to see it first hand so i am seeing if any of you guys know
Thanks Alot!!!
