Results 1 to 6 of 6
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Question why is my a/c not cold?
    ok well when i put it on the a/c mode and lowest temp even with it circulating. Even though the circulating button/signal doesnt ever want to stay on. My a/c just isnt cold at all. Like it doesnt want to get cold and i end up just rolling my windows down because it doesnt do shit..
    So what do i need to do? Recharge my a/c? BTW i have a clean cabin air filter in if that helps at alll....
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    Re: why is my a/c not cold?
    recharge it. the freeon is most likely done for
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    my a/c wouldnt get cold yesterday, i checked the temp outside on my cluster computer it said -40 degrees!!(it was really 90 degrees outside) so i turned off the a/c waited about 30mins watched the temp. rise back up and turned the a/c back on...cold air....i dont get why it did that, it has never done that before but it works great now!
    check that, i know if the computer is telling the car it is freezing cold outside your a/c will blow accordingly....so when its hot it blows cold when its freezing cold it will blow warm....
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by ////D View Post
    I don't think our cars use freon anymore. I believe it is R134.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    ILoveT is right and I think it might even be R134a. My a/c would get cool but not cold so since I'm doing an internship at an audi/porsche shop we put more R134a in and now it blows cold like it should. You probably just need to have it recharged. The humidity and weather can also effect how well the a/c works.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Nov 19 2005
    WA
    I would check the pressure with a gauge. You can buy R134A recharge kits that come with a gauge built in, it's rather helpful.
    Mine was doing the same thing last summer, and it sucked down here in FL, but a quick recharge fixed it, and it blows ice cold after 5 mins of cruising.
    2017 Platinum Gray Metallic Golf Alltrack SEL
